Main > Main Forum
Joystick Recommendation
Pages: << < (2/2)
severdhed:
yeah, true.  but installing a 4way restrictor on a u360 is like having a car that only turns left.
mj147:
--- Quote from: severdhed on July 20, 2009, 01:21:14 pm ---yeah, true.  but installing a 4way restrictor on a u360 is like having a car that only turns left.
Ermm......NASCAR?  ;D
Seriously, have you looked into a Japanese Sanwa or Seimitsu sticks? Both have small profiles especially when mounted without the mounting plate.
mj147
Ginsu Victim:
Well, the circular and octagonal hurt nothing. I see no point in using the 4-way/8-way, though.
bkenobi:
If you top mount the stick, you cut down the thickness of the CP in the needed space underneath.  I don't personally like that look nearly as much, but if you don't have options, it will work.
severdhed:
--- Quote from: mj147 on July 20, 2009, 02:19:25 pm ---
mj147
dont get me started on NASCAR...watching nascar is about as much fun as playing ET on the atari 2600
Pages: << < (2/2)
Go to full version
