Author Topic: Help me build my own spinner!  (Read 2056 times)
hellothere123
  • Last login:March 02, 2021, 03:39:27 am
« on: July 17, 2009, 09:09:18 pm »
I'd love if someone would direct me to  some instructions on building my own spinner.
From my searches I've looked for I see a bunch of older guides, just wondering which one is most recommended.
And no I don't want to buy a spinner right now...thanks!
severdhed
  • RIP Dinosaur Hippo
Re: Help me build my own spinner!
« Reply #1 on: July 17, 2009, 10:27:34 pm »
i'll try to find a link tomorrow to the guide i used, but i made one using parts from an old pc hard drive.  it worked pretty well, but i found that i rarely ever used it, so i didnt bother putting it back in my new panel
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 02:20:28 pm
« Reply #2 on: July 17, 2009, 11:56:40 pm »
Free VGA Breakout Cable
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: July 18, 2009, 12:15:17 am »
If you mean the Arcade Stupidity link, unless it has moved somewhere else, that link doesn't work anymore.
jholman76
« Reply #4 on: July 18, 2009, 01:06:40 am »
meh, this reminds me I was going to write up a tutorial on how to make a nice spinner from the old Maxtor "slim" hard drive, a microsoft mouse, some super glue, and a project box.
sorry.. I'll see what I can muster up. Its quite easy and doesnt involve much more than clever mounting to the CP.
Ginsu Victim
« Reply #5 on: July 18, 2009, 08:57:17 am »
My hack used an optical mouse. Been working fine for over a year so far.
severdhed
« Reply #6 on: July 18, 2009, 01:10:16 pm »
yeah, that's the one i used.  it was pretty simple.  but it is hard to find a hard drive that will work with that method.  when it was time to build one for my friend, we used a similar method, using the center spindle from the hard drive, with an optical mouse PCB mounted below it
jholman76
« Reply #7 on: July 18, 2009, 02:16:25 pm »
I stumbled apon the perfect drives for spinners at work one day. It has a spindle that spins on the top and on the bottom. Quite hard to find.
(NEVER USE THESE AS STORAGE DRIVES.. THEY ALL FAIL)
The Drive: Model Maxtor 2b020h1
http://www.joeholman.net/arcade/spinner/01.jpg
In the middle of the spindle, there is a shiny spot. If there is a shiny silver sticker on the middle of the spindle, you got a winner. If it is solid metal... sorry.
http://www.joeholman.net/arcade/spinner/02.jpg
http://www.joeholman.net/arcade/spinner/03.jpg
Spindle Removed (notice the nice mountable area with the 3 screw holes)
http://www.joeholman.net/arcade/spinner/04.jpg
Back Side with a Mouse chopper superglued to the back of the spindle
http://www.joeholman.net/arcade/spinner/05.jpg
Mounted to a test half-box (Had to use some spacers from another HDD Spindle to make it taller)
http://www.joeholman.net/arcade/spinner/06.jpg
Not so bad, eh? Going to do a smaller hole next time
http://www.joeholman.net/arcade/spinner/07.jpg
The Counter-sunk screws for the mount
http://www.joeholman.net/arcade/spinner/08.jpg
The guts of the hack. I have some other mice that have much smaller boards, but this works just fine. notice the cables to the left for the mouse buttons. nice to do for future expansion, if you want
http://www.joeholman.net/arcade/spinner/09.jpg
I'm trying to collect these as I can at work, so hopefully if anyone has interest I can send them your way. I'll post info if I get enough.
« Last Edit: July 18, 2009, 02:27:25 pm by jholman76 »
Bluedeath
  • Last login:June 19, 2014, 11:20:09 am
« Reply #8 on: July 20, 2009, 04:38:00 am »
ive done the arcade stupidity hack nd worked fine but i was disappointed by the low resolution of the mouse i used, I'm thinking to build a bigger opticall wheel (wht more teeth) to overcome the problem.
I give up  fighting keyboard dislexia, I lost.
vidmouse
  • Oop! Ack! Thppphbt!
    • Vidmouse's Arcade
« Reply #9 on: July 20, 2009, 01:11:54 pm »
I ended up using VCR parts, following this very helpful tutorial by krutknut.
Here's how mine came out (WIP shots)
jholman76
« Reply #10 on: July 20, 2009, 11:18:29 pm »
I think you get points for using a wine bottle cork AND duct tape... nice, but you need some hot glue in there and a spring clamp  ;)
vidmouse
    • Vidmouse's Arcade
« Reply #11 on: July 21, 2009, 09:31:10 am »
Whaddya think is holding the wine cork down?  ;D
J/K, that's actually super glue...
