Main > Main Forum
.187 Female Quick Disconnects
<< < (3/3)
Tiger-Heli:
--- Quote from: Chris on July 10, 2003, 01:49:36 pm ---The blue-ended ones are for 12-16 ga wire... too big for control panels.  You need the red-ended ones, which are for 18-22 ga wire.  I've found the red-ended .187 disconnects at Ace Hardware; Home Depot only has the .250's here...
Bob Roberts has the fully insulated ones at $5.00 for 50.  Mouser.com has the partially-insulated ones at $8.10 per hundred (159-2817).
--Chris
And, as I said, allelectronics has the red or blue ones (partially insulated) at $4.50 for 100 (plus $6.00 flat shipping).
u_rebelscum:
--- Quote from: Peale on July 10, 2003, 02:39:47 pm ---
What?  Bologna.  I've wired my CP with the blue ones just fine.  They come in especially handy when you're putting more than one wire per connection.
I suppose it also depends on what gauge wire you're using on your CP.  I've used CAT 5-E, and it worked really well.
Really?  CAT-5 is usually 22-24 gauge, IIRC.  Not that I'm disagreeing with you.
I used 20 gauge wire, and red ended ones for the NO wires (single wire connection), and blue ended ones for the GND wires (two wires per for the daisy chain).  I could not fit two wires in the red ended ones.  *shrug*  I liked it once it was done, because not only were the wires color coded, but so were the disconnects.
SirPeale:
--- Quote from: u_rebelscum on July 11, 2003, 02:24:03 am ---I used 20 gauge wire, and red ended ones for the NO wires (single wire connection), and blue ended ones for the GND wires (two wires per for the daisy chain).  I could not fit two wires in the red ended ones.  *shrug*  I liked it once it was done, because not only were the wires color coded, but so were the disconnects.
Yeah, I went with color coding as well, but with the wires that I used, as opposed to the connectors.  Since the grounds are all connected to the same spot, I didn't see the need.
u_rebelscum:
--- Quote from: Peale on July 11, 2003, 08:40:30 am ---
Uh, both the wire and connects were color coded for me.  Blue connects & black wire for ground, and red connects and red or green wire for inputs.  Color coding both is not needed, but it helps me. *shrug*
SirPeale:
Helped me too. I color coded the grounds as well, but didn't use black.  I used orange.
Navigation
Message Index
Previous page
Go to full version
