Author Topic: Good match for a balltop Ultimark Ultrastik 360?  (Read 1330 times)
GaryMcT
  • Last login:September 24, 2014, 11:19:27 am
    • GaryMcT's arcade blog
« on: July 12, 2009, 04:15:10 am »
I'm contemplating a layout that will work for Smash TV, etc, where there are two players with two sticks each.  I'm not sure that I want to spend the money on 4 Ultrastiks. . .is there a good look and feel match for the Ultrastik?  I'm planning on using the Ultrastik with a ball top, and I'll likely end up with the 8-way or circular restrictor on it.
Gary
My blog on learning how to develop FPGA versions of arcade boards: http://garymct.blogspot.com
mlalena
  • Last login:June 12, 2021, 12:31:44 pm
Re: Good match for a balltop Ultimark Ultrastik 360?
« Reply #1 on: July 12, 2009, 10:02:14 am »
Sanwa JLW is the same top as a U360.
I purchased a replacement Sanwa JLW bat from lizardlick to use on one of my U360s.
AlexKidd
  • Last login:July 28, 2010, 06:46:24 pm
« Reply #2 on: July 12, 2009, 02:25:43 pm »
I second mlalena's comment. I use two Sanwa sticks to compliment my two U360s and have them placed so that I can play robotron and smash TV.
arzoo
  • Last login:April 14, 2024, 11:15:11 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #3 on: July 12, 2009, 10:43:17 pm »
I've got two u360's with two Happ Supers. The balltops (red) are not a prefect match but pretty close.
Robots will kill you.
Arcade Addiction
Bender
« Reply #4 on: July 12, 2009, 11:31:03 pm »
in fact the U360 is a modified JLW so just get a couple of those and you can even trade parts and use the same routing template
GaryMcT
« Reply #5 on: July 13, 2009, 01:11:48 am »
Excellent!  Thanks for the info.  Even uses the same restrictors!  I think this is my lucky day. :)  Given the same restrictor, etc, do they feel pretty similar to the U360?
Ginsu Victim
  • Comanche, OK -- USA
« Reply #6 on: July 13, 2009, 10:06:51 am »
Well, there will be the obvious difference of the feel of microswitches on the JLW vs no switches at all on the U360. With the same springs and restrictors, the switch/no switch feel should be the only difference.
GaryMcT
« Reply #7 on: July 13, 2009, 01:37:12 pm »
Oh how I wish there were a GGG micro-leaf that would work with the JLW. :)  (Well, in theory. . . I haven't actually tried a micro-leaf yet.  Will put an order in soon.)
Ginsu Victim
« Reply #8 on: July 13, 2009, 02:19:52 pm »
Micro-leafs aren't really made for joysticks, however, it appears RandyT has a new product that might just do the trick! Awesome new item!
Versa-Micro™ User-Adjustable Arcade Switches
GaryMcT
« Reply #9 on: July 13, 2009, 02:25:26 pm »
Oooh, nice.  Works with joysticks too!  I may have to get some of those.  Looks like I have a huge order with Ultimarc and GGG coming up soon.  I also need to get some leaf buttons from Bob Roberts for my Defender machine to replace the springs.  FUN! :)
severdhed
  • RIP Dinosaur Hippo
« Reply #10 on: July 13, 2009, 05:14:50 pm »
just FYI...it is my understanding the the ultimarc J-stick is in fact a sanwa JLW.
Ginsu Victim
« Reply #11 on: July 13, 2009, 05:31:46 pm »
Seems right. Looks exactly the same. I wonder if there's anything different once Andy gets ahold of them.
GaryMcT
« Reply #12 on: July 13, 2009, 05:36:37 pm »
It says on his page that it's a JLW and that he mods them so that you don't need a tool to switch between 4 and 8-way.
Ginsu Victim
« Reply #13 on: July 13, 2009, 05:55:01 pm »
Ah, well there you go. I've never had much interest in them, so I didn't see that.
