Main > Main Forum
Some questions for Ultimarc Ultrastik 360 owners
GaryMcT:
--- Quote from: Franco B on July 11, 2009, 01:40:34 pm ---I did a U360 etc top mounting guide [here] if it helps.
Very nice! I'll be using this today as a guide on some test wood and test joysticks. :)
You and Bender not only build the nicest stuff, you are also both insanely helpful. :)
Bender:
Thanks, ^^
I checked out sinistar and it works great with the circular restrictor, you might have to play with the analog settings in mame for that game to get the exact feel you want, I put the auto centering to 0 and the sensitivity to 50
Hogie1418:
--- Quote from: Bender on July 11, 2009, 04:35:35 pm ---Thanks, ^^
Are you doing this under the tab settings or in the ini. File itself?
severdhed:
i bought the bat tops, with medium springs, longer shafts, and octagonal restrictors.
i immediately installed everything, but just couldnt handle the feel of the octagonal restrictor. i just didnt like the way it prevented any kind of smooth movement, plus the throw seemed way too short.
so i bottom mounted them in a 3/4" panel with the long shafts and no restrictor...but the throw was just too long that way. I ended up going back to the regular shafts and medium springs. the throw feels perfect now, although they are just slighly shorter than i would have preferred...i think i'll end up top mounting them to get the length back.
Bender:
--- Quote from: Hogie1418 on July 11, 2009, 04:48:26 pm ---
Tab settings so you can do each game individually (seems like all the analog games need different tweeks)
