Main > Everything Else
Outdoor movie screen
ChadTower:
It has been raining in the entire northeast pretty much since April.
shardian:
--- Quote from: pinballjim on July 16, 2009, 07:41:11 pm ---Oh yeah, I forget you guys have humidity in the rest of the country. Ah well, seemed like a cheap material to play with.
That and it weighs a ton compared to a piece of cloth and some PVC!
shardian:
--- Quote from: Wade on July 16, 2009, 03:48:32 pm ---
--- Quote from: shardian on July 13, 2009, 06:24:34 pm ---
--- Quote from: shardian on July 13, 2009, 11:33:18 am ---It also made it painfully obvious that fixing the marquee and coin door lights in some of my games has become a priority.
Marquee lights - check!
The Narc and JK are MAME, so I need to make wiring harnesses to plug into the power supply of the PC's. That or hack a wall wart. The CP glass on the Xevious has had the light wiring cut. I have the wiring, I just need to pull the game out to run the new power cord. Coincidentally, I figured out why the speakers and colors were all messed up - the pcb had fallen off the old mounting feet in the cab and the jamma harness was loose. I reached through the coin door and got the harness back on right - so now the game is 100% again. Sweet! It's amazing what you can accomplish when you get a free 30 minutes in the gameroom. :)
Sweet! It's looking like a real gameroom. Gamerooms HAVE to be dim to be proper. :) A couple mood lights are okay, or one over the pool table or what not, but the flourescent? No way.
I've found that even if I turn off all the overhead lights and only use the neon lights and billiards light, my room ends up being too bright! Sometimes, less is more. :)
That said, I still often think about getting some game related neons for the classics room!
Wade
Thanks Wade. You need to come to the next 80's movie night!
I picked up the stuff to fix the control panel glass light on Xevious. I decided to try out a blacklight bulb there. It is worth a shot to see what it looks like.
ChadTower:
Nothing complex but very nicely done.
Vanguard:
Have you guys seen this:
http://backyardtheater.com/
It's the arcadecontrols.com of outdoor movies. I think I actually learned about this site on this forum.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
