Main > Everything Else
Recommend me an MP3 player
<< < (2/3) > >>
mccoy178:
--- Quote from: pinballjim on July 09, 2009, 04:50:06 pm ---Anyone got a good iTunes alternative suggestion?  Don't want to load that bloatware onto my new setup.   :P
I've had no issues on my mac's with it at all.  Since the discovery of podcasts some time ago, I love it.  I plug the nano in at night and take off with it in the morning.   :afro:
wp34:
It is a little above your budget but the iTouch is a good value if you want more than an MP3 player.  It is basically an iPhone that you can't make phone calls with (but also no monthly fee).
You can install games and other programs from the App Store.  It has built-in WiFi so you can check email and surf the web.  It has a great screen for videos as well.
SithMaster:
I wouldn't be surprised if you could only use iTunes which I'm positive is the case.  When I installed rockbox on my ipod I found out about their silly naming convention of the songs.  It really made no sense so I would assume that unless you install rockbox like mentioned above you are stuck with itunes.
ahofle:
I've used this before to avoid the iTunes virus:
http://www.yamipod.com
--- Quote from: SithMaster on July 09, 2009, 04:48:47 pm ---Does your micro have any audio jack problems (mine did)?
Hmm no I haven't (I have 3 of them too).  I did get them refurbished, so maybe that issue has been fixed?
SithMaster:
--- Quote from: ahofle on July 09, 2009, 05:41:54 pm ---I've used this before to avoid the iTunes virus:
I think it was a bad soldering job so the common fix was to jam some paper under the metal shield to keep it from moving.
If the only problem with yours is the battery why not get a new one (battery or micro).  Apparently you can swap the mini disk drive with a cf card so you can get your memory into the range you want.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
