Author Topic: crimp-style db25 question  (Read 791 times)
GaryMcT
  • Last login:September 24, 2014, 11:19:27 am
    • GaryMcT's arcade blog
« on: July 08, 2009, 11:52:21 pm »
I bought some male and female db25 connectors at RadioShack that use crimping instead of solder (since my eyes suck bad enough that soldering is nearly impossible) along with a tool to crimp.  The tools says that it works with three different sized pins (20, 24, 28), but the connectors don't bother to mention what size the pins are.  Any ideas?
Here's the crimper:
http://www.radioshack.com/product/index.jsp?productId=2103683
female connector:
http://www.radioshack.com/product/index.jsp?productId=2102865
male connector:
http://www.radioshack.com/product/index.jsp?productId=2102864
Gary
My blog on learning how to develop FPGA versions of arcade boards: http://garymct.blogspot.com
Havok
  • Trade Count: (+17)
Re: crimp-style db25 question
« Reply #1 on: July 09, 2009, 12:04:33 am »
That should work fine. I forget which size to use, but just try and crimp one connection and see if it's tight enough. If it isn't, go on to the next smallest.
You do have to remove the pins to crimp one at a time, so you should pick this up:
http://www.radioshack.com/product/index.jsp?productId=2102600
And this when you're done:
http://www.radioshack.com/product/index.jsp?productId=2102869
MonMotha
« Reply #2 on: July 09, 2009, 12:42:09 am »
The numbers listed on the crimper are in AWG (american wire gauge).  The contacts are likely good at either size.  Basically, the smaller section is for 24-28AWG, and the larger section is for 20-24AWG.  24AWG can go in either size: you pick which one based upon insulation thickness.
I've never been a fan of the crimp style.  I usually have at least wire on a 25 pin connector break off (either due to being overcrimped or undercrimped or just getting unlucky), and it's extremely difficult to back the contact back out for replacement.
GaryMcT
« Reply #3 on: July 09, 2009, 02:02:26 am »
Ugh, having a terrible time with this!  Soldering was a bug giant fail since everything is so small on the db25.  The pin things tend to break. . . I think I'm going try again and just get a couple db25 cables, cut off the ends, label the individual wires, etc.
What I'm trying to do is to basically have a db25 coming out of a i-pac4 with the 24 (+ground) most important connections so that I can build multiple control panels to go with it.  I'm also building a converter from a Defender control panel harness to db25 as a tester.  Hopefully cutting up an existing cable will work just fine . . hopefully they are fully populated.  I'll stop by vetco tomorrow and see what they have.
Gary
GaryMcT
« Reply #4 on: July 09, 2009, 02:07:05 am »
If all else fails, I'm going to get one of these for the ipac 4 side:
http://www.winfordeng.com/products/brk25.php
  • Last login:May 06, 2024, 04:33:26 pm
« Reply #5 on: July 09, 2009, 09:44:53 am »
Juts get DB25 cables and cut them in half.  Monoprice has them for cheap.
GaryMcT
« Reply #6 on: July 09, 2009, 02:31:20 pm »
Thanks!  I finally figured that out last night and ran by Vetco on the way to work and picked up a M/F fully populated DB25 cable.  Excellent!
I've sworn to avoid trying to solder anything that tiny anymore. :)
