Author Topic: Any help with key mapping for z26?  (Read 1113 times)
BigDaddyE
  • Last login:October 02, 2012, 01:52:48 pm
« on: July 02, 2009, 06:37:16 pm »
My daily post for problem solving!
What is the easiest way to key map with the z26?
I read an old post that says it automatically maps, which it did, however, the player 1 and 2 buttons are all over my cp.
Ideas?
Eric
PS, I think I may have this thing done for the 4th party! Still will be incomplete, but very playable. I hope to put pics up on Saturday. Couldn't have done it without this community! Thanks! :cheers:
Someday this hobby will be easy for me!
BigDaddyE
Re: Any help with key mapping for z26?
« Reply #1 on: July 02, 2009, 09:53:41 pm »
Is there any documentation out there giving the assigned number to each key?
I can't find anything.
Thanks again.
Eric
bungy
  • Last login:February 06, 2020, 09:33:40 am
« Reply #2 on: July 02, 2009, 10:22:15 pm »
You can try using AutoHotKey.  But I think I tried that and it doesn't work.  On my system, I have a version of z26 that I modified and compiled myself.  The source code is available here:  http://www.whimsey.com/z26/z26.html.  I compile it with MinGW on windows xp.  Some of it is in assembly and some in C, luckily the parts you're looking for are in C.
BigDaddyE
« Reply #3 on: July 03, 2009, 12:00:44 am »
Wow.
This scares me!
No idea what I'm looking for, pretty intense though!
Eric
unclet
« Reply #4 on: July 03, 2009, 07:12:59 am »
There is a hacked version of z26 emulator which allows for key mappings via an INI file, so this is probably what you want.
   -  Go to the following site:
           http://www.emuchrist.org/cpviewer/applications.htm
   - Under the "Emulators" section, click on the "Atari 2600 - Z26 ver. 2.13 (jfath)" link to download it.
As an extra bit of information, here is a PDF file I found relating to z26, although I never looked into yet, but thought I would mention it.
     http://www.whimsey.com/z26/z26.pdf
I remember I started using z26 as the Atari2600 emulator but change to use the "Stella" emulator instead.  Have you tried the Stella emulator?
    http://stella.sourceforge.net/
Anyway, good luck
Congui
  • Last login:July 23, 2015, 12:54:53 pm
  • Newbie!
« Reply #5 on: July 03, 2009, 08:11:00 am »
There is also a version that already has the mame key mappings (no need for an ini file), which is the version I use.  You can find it at
http://www.whimsey.com/z26/Z26V213X.ZIP  (same site mentioned by Unclet)
Cheers, :cheers:
Congui
« Last Edit: July 03, 2009, 08:14:41 am by Congui »
unclet
« Reply #6 on: July 03, 2009, 08:29:37 am »
This might be the same as what I mentioned earlier ... "Atari 2600 - Z26 ver. 2.13"
I would assume z26 was updated to use an INI file and the default contents on the INI file are the MAME defaults.
BigDaddyE
« Reply #7 on: July 06, 2009, 01:46:34 pm »
Got it fixed.
Thanks for everyone's input!
Eric
