Main > Everything Else
UFC 100 predictions
CCM:
--- Quote from: ChadTower on July 02, 2009, 11:57:25 am ---
BTW, Lesnar is only like 10lb heavier than Mir. It's not so much his raw size that is the problem. It's that the guy moves like a middleweight.
He's 10lbs heavier at the weigh-in, Lesnar has to cut weight to get down to 265, Mir is always around 255. By fight time, Lesnar is probably closer to 280 and Mir is still 255ish.
ChadTower:
--- Quote from: CCM on July 02, 2009, 12:00:38 pm ---And we still really haven't seen Lesnar take a good shot to the face, I'm curious to see how he handles that.
We did see Lesnar moonsault off the top rope at Wrestlemania, eff it up landing right on his face, and still get up. Granted, no one hit him 5-6 times after that, but we at least know one dramatic shot to the face isn't going to put him out. That fall would have killed most people.
If he were facing a world class striker we could probably say that's irrelvant. Mir is not a world class striker.
Tim Sylvia used to cut to get to weight too. Difference is that he was a telephone pole. Being huge doesn't help much if you're a static target.
CCM:
--- Quote from: ChadTower on July 02, 2009, 12:05:55 pm ---
ugh... I'm not getting into a pro-wrestling/MMA debate... I didn't see Lesnar in wrestlemania, so I have no idea what it looked like. All I am saying is that we haven't seen him get hit hard in the face ... in MMA... Where like you say, he can get hit 5 or 6 more times before he regains his senses... And I wouldn't discount Mir's striking too much...
--- Quote from: ChadTower on July 02, 2009, 12:05:55 pm ---Tim Sylvia used to cut to get to weight too. Difference is that he was a telephone pole. Being huge doesn't help much if you're a static target.
That's not the point, you pointed out that Lesnar is only 10lbs heavier than Mir, which by fight time simply isn't true.
ChadTower:
--- Quote from: CCM on July 02, 2009, 12:18:34 pm ---That's not the point, you pointed out that Lesnar is only 10lbs heavier than Mir, which by fight time simply isn't true.
It's not a black/white issue like that. I can also say Mir doesn't have to cut 20lb to make weight so he's the fresher man at fight time.
CCM:
--- Quote from: ChadTower on July 02, 2009, 12:42:14 pm ---
jesus... I was just pointing out that by fight time Lesnar is closer to 25lbs heavier than Mir, not 10lbs... I said nothing about how that effects the fight...
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
