Front End Support > Maximus Arcade
Maximus Arcade and Romlister problems (or my stupidity)
NOP:
ok, that's super cool.
Currently, RL creates the text file, runs convert.exe, then deletes the text file, as I assumed you wouldn't need it anymore.
My life would be much simpler if I didn't delete the file and told you to go run the GLC program.
I'd have to check to make sure that GLC uses the same text formatting as the file RL creates, but this really sounds like a winning solution. Removing code from RL is a job I think I can handle. ;)
UFO8MyCow:
I am having the same problem. I have been at this for two nights now and still no luckI am able to save the lists as a lst file and see them in windows explorer but when i import them with maximus they dont show up.
UFO8MyCow:
Can someone please help me out with this? I really like MAximus but If I cant get this figured out soon then I will have to find another frontend
DeLuSioNal29:
Can you attach your .lst file to this topic? Rename it to .txt first before attaching. Then we can rename it back.
D
UFO8MyCow:
I finally figured it out. I was saving the files as "Fighter.lst" the files need to be saved as "MAME_Fighter.lst".
Navigation
[0] Message Index
[*] Previous page
Go to full version
