Author Topic: Need a motor  (Read 759 times)
Haterot
  • Last login:November 09, 2012, 09:27:41 am
Need a motor
« on: June 29, 2009, 08:32:31 pm »
My search-fu is weak it would seem.  I am re-configuring my rotating monitor and am in need of a new motor.Something that will be able to have a Sprocket mounted to it to drive a #25 chain. it has to be between 5-12v and spin in both directions (the ability to brake or pulse would be good too). I have checked several sites and come up empty.
Can any of our electrical engineers recommend something for me?  :notworthy:
Empire had the better ending. I mean, Luke gets his hand cut off, finds out Vader's his father, Han gets frozen and taken away by Boba Fett. It ends on such a down note. I mean, that's what life is, a series of down endings. All Jedi had was a bunch of Muppets
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Need a motor
« Reply #1 on: June 29, 2009, 08:35:23 pm »
Ken/rebelscum/ any other tech heads around?
Cornchip
  • Last login:December 27, 2023, 10:23:11 am
  • Thinking up more crap....
Re: Need a motor
« Reply #2 on: June 29, 2009, 11:09:03 pm »
 What's your current setup?
« Last Edit: June 29, 2009, 11:22:09 pm by Cornchip »
SavannahLion
Re: Need a motor
« Reply #3 on: June 30, 2009, 01:38:44 am »
Windshield wiper motors are plentiful, relatively cheap, run off of 12v, some models have reasonably high torque (don't know how much though), and some models are continuous rotation. I don't know what its stall current is though.
Drill motors operate on a range of voltages and battery powered motors can usually run on 12v. Most people tend to toss their battery powered drills when the batteries are no longer available and the originals have gone bad. You'll need the gearbox to get the appropriate torque though.
On a slightly more expensive note, motors used for wheel chairs are an option. I've seen their voltages vary all over the place but I have seen them for 12v (and 24v) systems. Their torque is good and they're rock solid durable.
Blanka
Re: Need a motor
« Reply #4 on: June 30, 2009, 02:19:39 am »
Do you really need rotating? I think its easier and cheaper to invest in a good screen that has 19 inch vertical space and 27 inch horizontal (like may cabs were) than to turn your cab into a mess, and your efforts into frustration (hardware and software-wise!) with a rotating mech.
Franco B
Re: Need a motor
« Reply #5 on: June 30, 2009, 04:54:49 am »
What type of monitor are you trying to rotate? Did you see the LCD rotational awesomeness in Onds build? [Linky link]
Haterot
Re: Need a motor
« Reply #6 on: June 30, 2009, 07:53:39 am »
current setup  http://forum.arcadecontrols.com/index.php?topic=92591.0
Im turning a 21" LCD. the problem is the motor turns a friction wheel and I think the sheer weight and inertia is to much, so I decided to go to a chain drive.
Franco, just saw that link and that could be an idea to try also. I already have the h-bridge and actuator switches. My whole rotating mechanism probably cost less than 75 bucks, so Ond's price tag of $500 is a bit high.
SavannahLion  I do have an old cordless drill lying around I might tear that apart. The windshield wiper motor might be a way to go also. A few rotating cab people have recommended that one. I might have to head over to the junk yard.
Blanka, at this stage I am seriously rethinking that choice. But between my rotating mechanism and monitor i spent less than 150 bucks. to get a monitor, like a WG or so would be at least 3 times as much so, frustration aside Ill stick to this until i can find a deal on a big monitor.
  • Last login:December 13, 2023, 12:03:14 am
Re: Need a motor
« Reply #7 on: June 30, 2009, 05:16:43 pm »
The shear "wow factor" alone is worth the extra effort of a rotating monitor, IMHO.
