Author Topic: Bezel for an LCD  (Read 1015 times)
Nemss316
  • Last login:April 28, 2010, 10:30:00 am
Bezel for an LCD
« on: June 28, 2009, 06:35:43 pm »
I've been looking around at a few sites for a bezel for a 19" LCD. I've found one through Happ $10, but I don't need anything else, and you need $25 to order.
Other than ebay, can someone recommend a site that sells bezels?
Encryptor
  • Trade Count: (+34)
Re: Bezel for an LCD
« Reply #1 on: June 28, 2009, 10:17:46 pm »
Look in the B/S/T forum for divemaster's thread. He can get anything Happ sells and has better shipping than Happ does.
Encryptor
Herk
  • Last login:May 26, 2020, 02:50:02 pm
« Reply #2 on: June 29, 2009, 02:26:32 pm »
Nemss316,
     You can goto a craft store and get foam board any colour and just cut it to what you need.  It will cost between $2-$10 depending on thickness.  Most foam board will have a white back, white foam inside and colour front.  The colour front usually comes in a matte finish.  If you can't have any white showing on the inside edges, there are black ones all the way through as well.  Don't use marker to colour the inside foam because it will shrivel up the foam.  (You can form the foam and actually bevel the edges quite nicely with practice using a magic marker).  This reply is only for a do it yourself solution.
Herk
  • Last login:May 06, 2024, 04:31:28 pm
« Reply #3 on: June 29, 2009, 06:16:32 pm »
Use matte board.  It's like $3 for a sheet.  Cut it with a straightedge and razor - it looks GREAT.   :cheers:
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #4 on: June 29, 2009, 08:24:24 pm »
Nemss316,
Herk
Seconded. Foam board or mountboard/posterboard. tape it to the upper and lower edges of your perspex/glass and you're good to go, plus you can show/hide as much of the monitor's actual bezel as you want.
If you have the tools, just cut one out of wood, thenround off the inner edge and use an arced router bit for a nice wooden bezel.
Blanka
« Reply #5 on: June 30, 2009, 02:29:19 am »
Just paint the glass. Use tape to keep the hole clear.
