Main > Everything Else
So...wouldja buy a GM?
<< < (14/20) > >>
Fordman:
PM me and I need your Full name, address, last four of your SS#, car you currently have, trade in or not, car you want to buy (although you dont have to use the X-Plan on your first choice. If you tell me F-150 but buy an Edge you dont have to get a different X-Plan pin #).
It only takes about 2 minutes for me to generate an X-Plan pin #
after I generate the X-Plan Pin# I'll keep it valid for 30 days if you decide not to use it!
Also, just because I gave you an X-Plan pin # doesnt mean you have to use it or agree with me and my posts!  :cheers:
Fordman
LLUncoolJ:
Very noble Fordman. I may take you up on that later in the summer if my wife's Mitzubishi nickel and dimes me (just dropped $400+ on some fuel tank sensor that was causing a check engine light to come on...apparently it is not vital, but it would stay on and if something else went wrong you wouldn't know).  :timebomb:
Fordman:
I'm no mechanic, but I play one on BYOAC - Forums - Everything Else!  :dizzy:
LLuncooJ - change the gas cap, take the positive off the battery for 10 minutes, see if that clears the code and if it throws the same check engine light. If it does, check the gasoline fill line at where the neck attaches to the body of the car for any air leaks. This is the number one Check Engine light code problem. If thats not it, check the O2 sensor.
Pinballjim, losen the bolts, put in some permatex gasket sealer, titghten the bolts 3-5 nm beyond what the book calls for, scrape off any excess or squeezed out permatex, let it run, heat up then let it sit over night. After it has cooled, take a sharpie and color the blue to black so it wont get noticed. Then drive it for a few days and see if you may have fixed the leak temporarily, then trade it in on a nice new F-150! PM me for the X-Plan Pin before you buy. If you want, get the vin # and dealership name-town and I'll look up the X-Plan for you on a particular vehicle!
Fordman
Fordman:
Wow, if you could find one for $20K , then sign for it! I'll have to wait until July 1 to see what deals they have for July as it is the last day of June and the deals end rather suddenly the last 3 days of the current sales month.
I'll check the inventory of the zip code you gave me at about 10:00AM Eastern time
Fordman
Fordman:
just PM me a valid email address and I can get you access to the AXZ pricing website.
I didnt know I could do that, but I can. You get an email invitaion from Ford, follow the steps (hoops) and search dealer inventory with the X-Plan price. It also shows the A-Plan price.
Fordman
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
