Main > Everything Else
Is there a way to unzip a whole bunch of files together?
CCM:
--- Quote from: Namco on June 25, 2009, 06:46:22 pm ---
--- Quote from: CCM on June 25, 2009, 05:46:02 pm ---pkunzip *.zip destination
Man, that brings back some memories
Yea, I still use a lot of old school command line stuff.
Flake:
--- Quote from: ahofle on June 25, 2009, 06:10:03 pm ---You can download 7zip, it comes with a command line tool that should handle everything.
ditto........way better application than winzip and winzip cost frieckin' money.
Thenasty:
if you have WINZIP installed, just select all your ZIP FILES and then RIGHT CLICK/DRAG over a bit to the side where it is a empty spot, then click UNZIP HERE.
Namco:
--- Quote from: Thenasty on June 25, 2009, 10:48:36 pm ---if you have WINZIP installed, just select all your ZIP FILES and then RIGHT CLICK/DRAG over a bit to the side where it is a empty spot, then click UNZIP HERE.
That's a GOOD TIP, man. The last time I had to extract hundreds of files, I couldn't figure out how to do it in Winzip so I went out to look for the old pkzip. Turns out it was called command line pkzip and they were charging for the full version. Go figure.
SavannahLion:
--- Quote from: Namco on June 25, 2009, 11:05:21 pm ---
Wow, PKZip is still around? I used to use it back in my college days. I would use a trimmed down version of PKZip on a floppy to borrow a bunch of programs from the school server, compress them onto a bunch of floppies I had with me and then do my homework at home. This was before we were allowed to remotely connect to the mainframe from off campus.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
