Author Topic: happ comptetition question  (Read 1032 times)
mariox2098
  • Last login:May 31, 2023, 01:26:06 pm
« on: June 24, 2009, 02:23:16 pm »
Well i set up the joystick but there doesnt seem to be any space for the E clip to connect to the metal rod. I knew i wouldnt be able to explain it well so i took a picture. Am i doing something wrong here?
Ginsu Victim
  • Comanche, OK -- USA
Re: happ comptetition question
« Reply #1 on: June 24, 2009, 02:28:45 pm »
You need to push it down. There's a spring pushing it up, so you have to push it back. Also, where's the actuator? It should be square.
mariox2098
« Reply #2 on: June 24, 2009, 02:35:58 pm »
I tried pushing it down really hard but its not budging and i feel like i might break it lol. btw, I just left the actuator off for the picture.
Ginsu Victim
« Reply #3 on: June 24, 2009, 02:39:15 pm »
Are you pushing back against the knob of the stick itself? If not, you'll get nowhere.
RandyT
  • Last login:Today at 11:46:17 am
    • GroovyGameGear.com
« Reply #4 on: June 24, 2009, 03:13:02 pm »
Put the square actuator on there and push down on it (the actuator).  It should expose the groove.
RandyT
Ginsu Victim
« Reply #5 on: June 24, 2009, 03:17:39 pm »
Yeah, now combine what Randy said and what I said.
mariox2098
« Reply #6 on: June 24, 2009, 04:18:58 pm »
i got it. thanks for the help guys
