Author Topic: 10X Better played vertical  (Read 1718 times)
Gavica
  • Last login:March 05, 2011, 09:56:15 am
« on: June 23, 2009, 01:31:50 am »
how could I fit my monitor in my cab?  :dizzy: looks sweet vertical, hadn't tried it before.
csa3d
  • Will game for food
    • Galaxian Mame Conversion
Re: 10X Better played vertical
« Reply #1 on: June 23, 2009, 02:25:16 am »
Buy a flush mount VESA mount, attach it to a cross beam, and attach that cross beam to the interior walls of your cab?
-csa
garwil
  • Last login:August 10, 2022, 12:52:30 pm
« Reply #2 on: June 23, 2009, 03:26:25 am »
I'm planning on doing that, except make it a rotating monitor. My plan is to buy a VESA mount, cut out a circle of MDF, screw it all together and wire it up to a motor of some sort. Then I just have to work out how to get HyperSpin to rotate it for vertical games!
Triangel7D
  • Last login:September 10, 2017, 01:06:09 pm
« Reply #3 on: June 23, 2009, 07:35:58 am »
I'm using this mount in the old cabinet I'm converting:
http://www.ergotron.com/Products/WallMounts/tabid/157/ctl/Product/mid/543/PRDID/123/Default.aspx
I decided a while ago not to go the motor route and keep it simple (less moving parts=less maintenance).  It will be really easy to open the CP, reach in and turn it.  I'm far from deciding on a front end, though.  Mala? Hyperspin? MameWAH? Which of these will switch from a horizontal menu to a vertical on the fly?
csa3d
« Reply #4 on: June 23, 2009, 08:08:44 am »
You mean like this?  These are images from my project thread in my sig below.
-csa
Gavica
« Reply #5 on: June 23, 2009, 10:38:41 am »
what kind of monitor is better for this games, a 16:10 or a 16:9 ????
  • Last login:May 06, 2024, 04:33:26 pm
« Reply #6 on: June 23, 2009, 10:47:04 am »
4:3
Gavica
« Reply #7 on: June 23, 2009, 11:02:04 am »
4:3
for the vertical scrolling ones.
« Reply #8 on: June 23, 2009, 11:03:21 am »
4:3
3:4  ;)
mrclean
    • Guscade
« Reply #9 on: June 23, 2009, 11:38:37 am »
My advise is just get a big CRT. If you stick with the LCD, Make sure your LCD has good viewing angles, go off to the left / and right to see if the picture changes (while vertical). I had mine on a rotating vesa arm and ended up going with a CRT in the end.
I had this one: http://www.ergotron.com/Products/tabid/65/PRDID/126/language/en-US/default.aspx
was cheap and had it's own stand so no need to actually mount it to the cab itself..
2,370,650 Gun.Smoke
  • Last login:May 06, 2024, 04:31:28 pm
« Reply #10 on: June 23, 2009, 06:10:53 pm »
4:3
3:4  ;)
LOL - that is what I was going post after seeing 4:3   :laugh2:
« Reply #11 on: June 24, 2009, 05:18:58 am »
Sound advice...
