Main > Everything Else
Question about multi game jamma boards
ChadTower:
--- Quote from: Paul Olson on June 24, 2009, 01:00:25 pm ---If one is available at Target, definitely check to see if it is licensed for commercial use. I would imagine it would only be for home use.
Did the Target version even have coin mechs? Those things were cheap and would definitely not stand up to any sort of commercial use. Really rough play could rip a CP right out.
2600:
--- Quote from: RayB on June 24, 2009, 01:13:18 pm ---There's also the one from ArcadeShop where you hook it up to your PC to load it up with the ROM data. That one is probably legal. Technically, a reproduction of hardware is completely legal (patents expired), but including any of the original software is not (copyrights not expired).
That one uses emulation and isn't a reproduction of hardware. I think they use the PC thing to get around them being sued only the person using it.
Navigation
[0] Message Index
[*] Previous page
Go to full version
