Main > Main Forum
How easily swappable are Pacman/Defender control panels?
TOK:
--- Quote from: Turnarcades on June 20, 2009, 09:02:09 pm ---If making a modular or swappable panel, just using interfaces that have a USB connection should be sufficient as you just unplug the cable from the interface mounted on the panel and plug it into the interface on the swapped panel.
You mean having a separate keyboard encoder for each panel? That'd get spendy.
I think it would be better to have the encoder stay with the cabinet and have all inputs wired to a connector that connects it to the panel. I think people have used printer cables for this in the past.
I considered swappable panels when I did my first machine, but then decided I would rather have multiple games... I ended up with a horizontal a vertical and one with a dedicated Stargate layout that will also work for Defender and a bunch of other 1 or 2 button games.
bkenobi:
--- Quote from: TOK on October 23, 2009, 07:34:31 am ---You mean having a separate keyboard encoder for each panel? That'd get spendy.
So instead of spending an extra $20-40 on an extra encoder, you chose to spend a few hundred on more cabinets (including extra encoders)? My wife would have seen right through that logic! :laugh2:
GaryMcT:
--- Quote from: mytymaus007 on October 23, 2009, 07:22:49 am ---whats the latest on your control panel journey would like to see if you built anything yet
It's still in the prototyping phase. I keep building new versions and moving stuff around. I think I'm pretty close though now so that I can start thinking about getting some art on there and building a final one. I'll try to remember to put a picture up soon of where it's at.
CheffoJeffo:
--- Quote from: bkenobi on October 23, 2009, 04:47:42 pm ---My wife would have seen right through that logic! :laugh2:
So apparently you aren't the Jedi that you would have us believe that you are ...
TOK:
I used to bring motorcycles in the house. She considers this great.
Ya gotta break 'em in right. ;)
