Author Topic: What's this piece of hardware called?  (Read 1501 times)
cluster
  • Last login:June 17, 2009, 07:23:17 pm
« on: June 16, 2009, 12:40:25 pm »
What's the name of this piece of hardware?
Where can it be purchased?
  • Last login:May 06, 2024, 04:33:26 pm
Re: What's this piece of hardware called?
« Reply #1 on: June 16, 2009, 12:48:34 pm »
Hard to tell from the pictures, but I'm guessing it's a supergun?
cluster
« Reply #2 on: June 16, 2009, 12:50:38 pm »
Supergun?
It's essentially the hardware that you plug your jamma board into, and on one side you plug your two joysticks into, and on the other are video outputs etc.
If that helps any?  Will do some searched on Supergun and see if this is what comes up.
cluster
« Reply #3 on: June 16, 2009, 12:51:25 pm »
FYI: you were right.
What a stupid name.
Jack Burton
  • Last login:August 26, 2023, 11:32:31 pm
« Reply #4 on: June 16, 2009, 12:52:31 pm »
Looks like a MAS Systems Supernova.  I have one if you have any questions.
cluster
« Reply #5 on: June 16, 2009, 01:04:58 pm »
1) If I were to go this route, and buy a KI jamma pcb with flash kit, would I be able to hook up my X-Arcade Tankstick to the Supernova?
2) How much does the Supernoval itself cost?  I don't see a quote on the single unit, only bundled with those cheesy looking joysticks.
« Reply #6 on: June 16, 2009, 01:06:47 pm »
For as much as one of those things cost, coupled with the cost of a KI board & flash kit, you'ld be better off building a computer and playing through MAME.
cluster
« Reply #7 on: June 16, 2009, 01:30:15 pm »
For sure.
Wish I knew which way to go, I really just want the cabinet, but the wifey would kill me if I bought that and threw it in the living room. lol
« Last Edit: June 16, 2009, 01:32:03 pm by cluster »
Ummon
  • Trade Count: (+13)
« Reply #8 on: June 16, 2009, 10:48:57 pm »
So don't put it in there.
Yo. Chocolate.
Stephen Hawking
cluster
« Reply #9 on: June 17, 2009, 12:23:51 pm »
Good advise.  8)
severdhed
  • RIP Dinosaur Hippo
« Reply #10 on: June 17, 2009, 04:17:14 pm »
do what i did...bring the cabinet home when she isnt there, then tell her later..that way she can't say no... >:D
pick a theme so that you can name it after your children or something...it makes it easier.  my wife was not too pleased when i told her i brought home a cabinet, but then i named it ZakMan, after our oldest son (only son at the time) and that seemed to make it OK.
Jack Burton
« Reply #11 on: June 17, 2009, 04:23:57 pm »
You're telling me your wife wouldn't love SPINAL? >:D
This cab is the perfect centerpiece for the family room!
Just make sure that you play the KI main theme when you show it to her:
« Last Edit: June 17, 2009, 04:28:28 pm by Jack Burton »
cluster
« Reply #12 on: June 17, 2009, 04:51:15 pm »
"Common baby, since when didn't you like skeletons??"
SavannahLion
« Reply #13 on: June 17, 2009, 05:43:34 pm »
Wife probably threw a fit because of the condition that thing is in.
Ummon
« Reply #14 on: June 19, 2009, 01:45:36 am »
Good advise.  8)
<SMILES> I'm a fount of wisdom.
Yo. Chocolate.
Stephen Hawking
