Author Topic: Using Mouse as a Spinner  (Read 1070 times)
Searcher7
  • Last login:June 21, 2009, 10:45:22 pm
« on: June 13, 2009, 02:39:45 pm »
Can someone point me in the direction on a FAQ on how to get MAME(WolfMAME 106) to find a PS2 mouse.(For use as a spinner).
The arrow keys on my keyboard work with Arkanoid, but not the mouse. ?!?
Thanks.
Darren Harris
Staten Island, New York.
« Last Edit: June 13, 2009, 02:43:51 pm by Searcher7 »
Ginsu Victim
  • Comanche, OK -- USA
Re: Using Mouse as a Spinner
« Reply #1 on: June 13, 2009, 03:18:28 pm »
In the mame.ini you need to set Mouse 0 to Mouse 1
Searcher7
« Reply #2 on: June 13, 2009, 03:30:59 pm »
in the ini folder I have the following files:
arcadia
decocass
mame32ui
megaplay
neogeo
playch10
stv
I cannot see what you are referring to.
Thanks.
Darren Harris
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
« Reply #3 on: June 13, 2009, 03:55:29 pm »
Look in the Mame root folder itself.  It's not a file in the ini folder.
Searcher7
« Reply #4 on: June 13, 2009, 04:03:56 pm »
Can you tell me how to get to the "Mame root folder"?
Thanks.
Darren Harris
severdhed
  • RIP Dinosaur Hippo
« Reply #5 on: June 13, 2009, 04:11:11 pm »
the mame root folder is the folder that contains the mame.exe file.  the mame ini folder is insde the mame root folder.
Searcher7
« Reply #6 on: June 13, 2009, 04:18:19 pm »
Ok, It's in the ini folder, or it's not in the ini folder. I don't know what the MAME.exe folder has to do with this, and no one knows how to get to the MAME root folder...
Darren Harris
Ginsu Victim
« Reply #7 on: June 13, 2009, 04:58:20 pm »
in MAME32UI, go to OPTIONS, DEFAULT GAME OPTIONS, CONTROLLERS, and check the ENABLE MOUSE INPUT box.
Searcher7
« Reply #8 on: June 13, 2009, 05:32:43 pm »
The first pic my MAME 106 folder.
The second pic show what I have when I open the "ini" folder.
The third pic is the opened mame32ui notepad.
There is nothing that says "options" on any of the five drop down menus there.
Thanks.
Darren Harris
Ginsu Victim
« Reply #9 on: June 13, 2009, 05:35:42 pm »
You don't have filename extensions turned on. In the first photo, the one that says MAME and then "configuration settings" is the MAME.INI.
What I was saying in my last post was WHILE RUNNING MAME32UI, go to the options I listed.
Also:
The root folder is the first folder. The root of the C drive would be C:\ and assuming MAME is where it usually goes, the root of MAME would be C:\MAME (in your case, MAME 106)
« Last Edit: June 13, 2009, 05:37:44 pm by Ginsu Victim »
Searcher7
« Reply #10 on: June 13, 2009, 06:03:09 pm »
Also:
Thanks. That worked.
Now I can use either the PS2 mouse, keyboard arrows, or USB joystick to control the paddle in Arkanoid.
This will probably be temporary because I'm looking for a set-up that will only use a single USB port for spinner and buttons.
Thanks again.
Darren Harris
