Main > Main Forum
Button life cycle
<< < (2/2)
DJ_Izumi:
Sometimes part's just fail early.  That's what warrenties are for.
Namco:
Take it apart. Probably some plastic chaff from the molding process. Rub a bit of white lithium grease in the wall of the button and you should be good.
Jack Burton:
Physical button press mechanism = a spring.
Spring is no longer springy?
You gotta be shitting me if you're saying you wore a hole through the bottom of the plastic of your button.
Benevolance:
Basically, this button wasn't triggering the microswitch with consistency. You'd press the button, and sometimes it would stick in the down position. Other times it wouldn't trip the switch; like, you'd press and instead of feeling that point of resistance when the switch triggers, there'd just be nothing. The first few times I'd open the CP up, wiggle things around from the inside, and it'd work again for a while.
I already replaced it; I bought more buttons than I needed when I made my order. But I was more curious if others had this happen. Namco probably has the right of it and I will give his suggestion a try and see if it operates smoothly after that.
If not, well, it's $2. It'll obviously set my retirement plans back by a few years, but...
Kayden:
I had this same problem and it turned out to be little burs left over from the casting process.  I shaved them off with a strait edge razor and spun some sand paper around it and now they're silky smooth.
Navigation
Message Index
Previous page
Go to full version
