Author Topic: Top Mounted U360 Question  (Read 1541 times)
Punisher
  • Last login:December 06, 2009, 03:17:41 pm
« on: May 25, 2009, 03:16:59 pm »
This might be a stupid question but here it goes.  If you top mount a U360 and then cover it How do you remove it if you need to replace or fix it?  Don't they have screws holding the stick to the mounting bracket in the top?  I'm trying to decide wether I need to order the longer shafts and bottom mount the sticks.
Virge
  • Last login:June 02, 2009, 10:17:57 pm
Re: Top Mounted U360 Question
« Reply #1 on: May 25, 2009, 08:36:01 pm »
If you were gonna replace it, yes, you would have to take the top covering off.  I bottom mounted mine but I routered them in from underneath and never had to go with the longer shafts.  Seem to stick up far enough.
severdhed
  • RIP Dinosaur Hippo
« Reply #2 on: May 26, 2009, 12:46:36 am »
i'd recommend against the longer shafts.  i had them installed for a while, but even with the stiffer springs, they felt a little mushy, and the throw was really long.  after going back to the standard shafts, they feel much better
Todd H
  • Last login:February 17, 2024, 12:58:49 pm
  • It's Gameday!
« Reply #3 on: May 26, 2009, 08:24:50 am »
I have the longer shafts on my bottom mounted U360's and they feel fine. Just make sure in addition to the stiff springs you use the circular restrictor.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #4 on: May 26, 2009, 08:32:37 am »
Yeah, if using the long shafts, a restrictor is a must! The throw is too much with the regular shaft and even longer with the long one.
paulscade
  • Last login:December 26, 2022, 09:40:35 pm
    • My Arcade Project - Blastoff!
« Reply #5 on: May 27, 2009, 01:40:39 pm »
I went for top mounting all my sticks.
http://forum.arcadecontrols.com/index.php?topic=82241.msg891255#msg891255
Yes, I'll have to remove ALL the wiring quickconnects and ALL the buttons.
Yes, it's going to be a giant pain in the @#$% if I ever have to replace them but it's not the end of the world.
My thinking was that I wanted to use the stick as it was designed... without needing to extend shafts.  Extending the shaft and bottom mounting (great solution if you expect to replace it in the future) moves the pivot point of the stick lower giving the stick a different feel.
So... not so stupid of a question...
For me...  top mount = pain later, bottom mount = different feel.  I chose the former.
... Why is it that you always find it in the last place that you look? ...
gatordad
  • Trade Count: (+11)
  • Last login:March 29, 2024, 07:11:02 pm
« Reply #6 on: May 27, 2009, 03:50:19 pm »
I have my u360 top mounted and any repairs can still be performed from under side as long as your cp opens or you have access.
example I just replaced the small washers, I removed the pcb, removed magnet, removed e-clip joy pops out, put new washer on and reasemble, all from the underside. no problems.
Chris
    • Chris's MAME Cabinet
« Reply #7 on: May 28, 2009, 04:45:11 pm »
How deep did you router?
--Chris
