Main > Main Forum
What do you put around the monitor glass?
Visitor Q:
--- Quote from: javeryh on May 21, 2009, 03:58:06 pm ---I made a bezel out of matteboard for my LCD and had the glass rest on top of it. Nothing is secured - the monitor sits in the MDF frame I made and the bezel and glass sit on top of that. Gravity does the rest.
You can't see anything but the screen (only when it is on) otherwise it looks completely black in there.
Yup... More less what I did with mine as well.
http://forum.arcadecontrols.com/index.php?topic=87205.0
thecheat:
I'm using a piece of black foam core for my bezel. The back of the board is cut to the outside of the bezel. The front side of the board is cut to display only the screen. With a lot of patience and razor blades, it turned out pretty decently.
Siris:
Anyone know where to get this PDF from the link TheShanMan posted?
Build_Your_Own_Bezel.pdf
http://forum.arcadecontrols.com/index.php?action=dlattach;topic=17175.0;attach=3251
Dragonman73:
Does anyone happen to know of a seller that sells plastic bezels for 21" monitors?
I can find 19", 25", and 27" bezels all day long but no 21" :hissy:
saint:
--- Quote from: Siris on May 26, 2009, 11:13:11 pm ---Anyone know where to get this PDF from the link TheShanMan posted?
I assume you mean the one wj2k3 posted?
http://forum.arcadecontrols.com/attachments/Build_Your_Own_Bezel.pdf
