Main > Everything Else
Death of 3D Realms
<< < (7/8) > >>
Flip_Willie:
--- Quote from: ahofle on May 20, 2009, 09:48:00 pm ---
--- Quote from: Flip_Willie on May 20, 2009, 04:06:32 am ---I can't find it on the internet anymore, but I found a program a while back that makes it really easy to set up Duke lan games. If you are interested, I have uploaded it to my website here. It works great with Eduke32.
I'm getting what appears to be a corrupt zip file from that link.  You wouldn't happen to have another copy would you?  Thanks again.
Oh, I am very sorry about that. I should have check first.
EDIT FOR LINK: Actually, I found the original website. It appears that he has all the files you will need.
I hope that works.
ahofle:
Can't wait to try it.  And it supports TCP/IP!!!! YAY!
Oh, and the link is missing the 'ml' from the end: http://duke3d.sitesled.com/files/dukon.html
Thanks again!
Flip_Willie:
--- Quote from: ahofle on May 21, 2009, 12:26:06 pm ---Can't wait to try it.  And it supports TCP/IP!!!! YAY!
Thanks again!
Wow, sorry again. I thought I checked that.
Some brief instructions on how I have used Dukonnector. When you start, click Don't Connect to MS. Make sure to set up all the directories for the game.
When hosting more than 2 players, use the Master/Slave option. I haven't been able to get Peer 2 Peer to work for more than 2 players -- You could probably get it to work if you messed around with it.
For those joining, join manually by IP. Dukonnector conveniently lists all the necessary connection information on the host screen.
Obviously, make sure everyone turns off their firewalls.  8)
I am sure you could have figured that out, but I hope it helps anyway.
ahofle:
Dukconnector is trying to connect to a couple of sites right when it starts up.  www.sitesled.com and some other one.  That makes me a little nervous.  When I denied those connections with my firewall it just hangs.  Any ideas what those are?
Flip_Willie:
--- Quote from: ahofle on May 22, 2009, 12:22:21 am ---Dukconnector is trying to connect to a couple of sites right when it starts up.  www.sitesled.com and some other one.  That makes me a little nervous.  When I denied those connections with my firewall it just hangs.  Any ideas what those are?
--- Quote from: ahofle on May 21, 2009, 12:26:06 pm ---Oh, and the link is missing the 'ml' from the end: http://duke3d.sitesled.com/files/dukon.html
I honestly am not sure. If I had to guess, I would say it is probably checking for updates. Notice, sitesled.com is the same site that the files were hosted on in the first place. I would suspect that this is harmless, but I am not certain. At one point, they had a master server which they used for internet games. I am pretty sure there is no support for this anymore. It is possible that it could also be attempting to access information on the server.
EDIT: I took a quick look at the source code. It appears that it was intended to "Show News" at one time. I am fairly certain that any such functionality is now defunct.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
