Author Topic: how do you guys apply vinyl to mdf?  (Read 8668 times)
danny_galaga
  • Last login:Yesterday at 09:08:57 pm
    • dans cocktail lounge
« on: May 14, 2009, 05:53:55 am »
my thoughts are starting to drift back to my 75% complete SI reproduction. I'm thinking i should get the artwork printed and applied to inspire me to finish it off. but how DO you apply vinyl artwork to MDF? Should i prime it first?
  • Last login:Today at 07:54:28 pm
Re: how do you guys apply vinyl to mdf?
« Reply #1 on: May 14, 2009, 09:18:50 am »
Priming it would be a good idea just to seal the MDF.  Sand it smooth with at least 220 grit sandpaper.  I use 3M spray adhesive.  A light coat does the trick - lining everything up is the tricky part.  I use masking tape to get the art placed and then roll it on a little at a time and follow with a burnishing tool of some sort to avoid air bubbles.  It is nerve wracking!
ctozzi
  • Last login:November 24, 2022, 01:05:42 pm
« Reply #2 on: May 14, 2009, 12:05:10 pm »
spray on some 3M spray adhesive first that way it does not curl up on you
Current Cab's
Dedicated Killer Instinct 1
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
Bonesaw Ownage
  • Last login:March 26, 2011, 09:44:31 pm
  • Bonesaw is Ready!!
« Reply #3 on: May 15, 2009, 11:53:09 am »
3m is a great product, just make sure you buy the heavy duty spray mount, Also make sure you follow the directions. Spray on both surfaces, let it tack up, and then mount in place and smooth. Grab a vinyl smoothing tool for like a buck, it's definitely worth it.
-JC
Tekken 3 Showcase to 4 player Mame Conversion in progress.
Dedicated Die Hard
2x Dedicated Mortal Kombat   **For Sale**
Dedicated Mortal Kombat 2     **For Sale**
Dedicated Mortal Kombat 4 - soon to be UMK3
Dedicated TMNT 4-Player         **For Sale**
Dedicated Marvel Vs. Capcom
Xbox 360 Wireless Arcade Stick in progress.
Neverending Project
    • Arcade Fixer
« Reply #4 on: May 15, 2009, 01:23:57 pm »
If the MDF is sealed (painted or primed) then I would use the wet method. I used a mix of 50% water and 50% isopropyl alcohol in a squirt bottle with a few drops of dish soap. Tack one end and work your way down. Spray both the surface and artwork and then use a squeege to smooth it as you go and work the bubbles out.
Check out Rich's (from thisoldgame) description here:
http://www.coinopspace.com/profiles/blogs/installing-mappy-kickplate
Kevin Mullins
    • Me on Myspace
« Reply #5 on: May 15, 2009, 05:10:58 pm »
I agree...... If they are self-adhesive.
danny_galaga
« Reply #6 on: May 16, 2009, 03:29:14 am »
Ok, good food for thought. I don't think i'll use the wet method though because i don't trust myself to fully seal the MDF.
In a few more months time when i finally do this, i'll post some pics in ht project thread i started about 2 years ago  ;D
