Author Topic: Novagem CDR  (Read 1014 times)
genesim
  • Last login:April 12, 2010, 08:18:42 pm
Novagem CDR
« on: May 10, 2009, 09:49:46 am »
Tried the search and I can't find this exact answer...sorry if I missed it.
Can you put the Novagem CDR on after you have put the replacement coin door sticker?
I mainly worry about drilling a hole and tearing it up.   Anyone got tips on how to easily/or best way do this?
Re: Novagem CDR
« Reply #1 on: May 10, 2009, 09:56:41 am »
I assume the sticker is already attached? A good drill bit will go right through it. You could cut out the area with a razor blade (cut it a bit smaller) drill your three holes and you'll be good.
genesim
Re: Novagem CDR
« Reply #2 on: May 10, 2009, 10:44:53 am »
Why smaller?   I guess the key is to take it slow like with a variable speed drill.   Just don't want it to rip.
Great idea on the razor blade though.  Thank you.
Re: Novagem CDR
« Reply #3 on: May 10, 2009, 10:56:09 am »
The shroud of the CDR will cover up the hole you cut. Here is the hole I cut for my CDR
Everytime I've had to cut through the control panel overlay with a drill - the drill was spinning as fast as it could, and I slowly drilled the hole. My thought was that it will cut instead of catch.
When I built a 2 player bartop - I had to cut holes after the artwork was applied:
Notice the lack of 1-player and 2-player buttons. I have no idea how I forgot to add those, but I did.
I used a spade bit with the drill spinning at it's highest speed and slowly cutting the hole. I tried cutting both from the front and from the back and ended up with some wood chips under the artwork. The buttons covered it up nicely. End result:
genesim
Re: Novagem CDR
« Reply #4 on: May 10, 2009, 12:57:40 pm »
Wow now that is different!
Thank you again for the great advice.  Looks like I need to get to drilling!
genesim
Re: Novagem CDR
« Reply #5 on: May 10, 2009, 01:02:17 pm »
Been there too on the "how could I forget".   Matter of fact when taking apart my arcade to movement I couldn't believe the stupid crap I did after the fact that made it in possible to take it apart easy.  That has been fixed now...but only after I won't need to move it for a long time.
