Author Topic: How do I set a Mame configuration to "None"?  (Read 13476 times)
jhuie
  • Last login:April 10, 2013, 12:12:12 am
« on: May 09, 2009, 05:02:11 pm »
Ok, this should be very simple.  I know I can go manually edit the configuration file.  But when I hit TAB and would like to change something to "None", how can I do that?  Any key I press substitutes that key in rather than putting the "None" back.  Know what I mean?
CrazyKongFan
  • Last login:June 06, 2017, 01:22:29 pm
Re: How do I set a Mame configuration to "None"?
« Reply #1 on: May 09, 2009, 06:00:14 pm »
Assuming you're wanting to set a certain button in a game to <none>, after using TAB, select the button you want to set to <none>, hit ENTER, then hit the ESC key.
« Last Edit: May 09, 2009, 06:02:16 pm by CrazyKongFan »
jhuie
« Reply #2 on: May 09, 2009, 06:30:40 pm »
Thank you.  I see my problem....I'm using an older version of Mame.  this works fine on the current version but on the older one that I'm using when I do that it assignes the Escape key to that button.  I guess it's time to upgrade to the latest version unless there is a workaround for that.  Thanks again.
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
« Reply #3 on: May 09, 2009, 06:41:01 pm »
try delete key
just go over the key don't select it and press delete
jhuie
« Reply #4 on: May 09, 2009, 07:35:47 pm »
try delete key
That did it.  Sometimes the answer is so simple....thanks!
Ummon
  • Trade Count: (+13)
« Reply #5 on: May 10, 2009, 05:56:09 pm »
....I've never had that problem, regardless of version.
Yo. Chocolate.
Stephen Hawking
