Author Topic: How to Light up Happs Trackball  (Read 1739 times)
Poefue
  • Last login:May 19, 2009, 03:02:29 pm
« on: May 06, 2009, 08:08:33 pm »
Hey guys, Looking for any suggestions for how to light up my Happs trackball.  I thought about trying to find a small kind of lamp or mounting a blacklight underneath the CP.  Let me know which route I should go.  Thanks in advance.
whynotpizza
  • Last login:December 05, 2022, 08:26:35 pm
Re: How to Light up Happs Trackball
« Reply #1 on: May 06, 2009, 08:36:50 pm »
http://www.nicemite.com/LightmiteTB/LightmiteTB.htm
Works great for me!  :)
Runs off 5V line too for easy hookup.
  David
DrumAnBass
  • Last login:January 01, 2024, 11:39:59 pm
  • "I love this computer magic!" - Viv Savage
« Reply #2 on: May 06, 2009, 09:38:28 pm »
Not as slick as the LightMite but these can work as well for basic illumination:
http://www.jab-tech.com/4L-Laser-leds-c-302.html
"Some drink from the fountain of knowledge; I only gargle."
genesim
  • Last login:April 12, 2010, 08:18:42 pm
« Reply #3 on: May 08, 2009, 12:30:24 pm »
Are those light mite's extra bright?   I think I still have the stock ones in the Slikstik panel.
whammoed
  • Last login:Yesterday at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
« Reply #4 on: May 08, 2009, 02:36:22 pm »
I wouldn't call them "extra" bright.  They do use a super bright high flux LED.  They are adequate for a normally lit room.  They include a dimmer as some still find there is too much glare at full power.
I've only had one or two say they weren't bright enough for their taste, likely due to a very brightly lit room or a room that gets direct sunlight.
Keep in mind though you can assemble your own with up to 4 leds in whatever brightness you like.  Also you can get a little more brightness out of them by mounting them directly to the trackball instead of using the pcb mounting foot method.
genesim
« Reply #5 on: May 08, 2009, 03:42:45 pm »
I think it is more how dull the light that came with the CO2 stock.    I like the apparatus though.  Thanks for the heads up.
