Author Topic: Adjustable Monitor Brackets for 19"-27" CRT/LCD - only 1 left!  (Read 6065 times)
1UP
  • Token Junkie
    • 1UPArcade
UPDATE: I'm dropping the price on these to $50, since the economy aint what it was in 2005. :)  Paypal, Money Order, or Checks accepted.
These are exactly the same design as the ones offered thru Spincade in 2005.  They were professionally machined for cabinets that were never built.  These brackets were designed to be mounted to the side walls of a stand-up or cocktail cabinet with no externally visible hardware, although they can easily be modified to work with carriage bolts thru the side walls if you need to mount a heavier screen or use thinner wood.
The 6x22" anchor plates distribute the weight of the monitor over a large area, and when bolted to the monitor chassis, actually give added strength and rigidity to the cabinet.  I have personally driven a cabinet using these brackets and a 27" monitor over 100 miles in a bouncy U-Haul trailer, and shipped another cabinet by truck from LA to San Diego and they have held up like a champ.
The brackets are made of almost 1/8" thick steel, very rigid and strong.  They feature a 3-piece adjustable design to allow mounting in a variety of situations with different monitor sizes.  They were made to mount a 27" arcade monitor with universal mount such as the Wells Gardner D9200 or Betson Multisync digital CRTs, but should work with smaller monitors and arcade LCDs as well.
The brackets can be adjusted to a maximum distance of 20 5/8" between top and bottom mounting holes (standard for 27" monitors) and a minimum of 15 11/16" (for monitors as small as 19".)  The horizontal width can also be adjusted depending on the inside width of your cabinet.  For example, the minimum inside cabinet width for a 27" monitor would be 24.25" (but not less than the width of the monitor), and the maximum width would be 25.5".  The minimum distance between the inside wall and the mounting hole on each side of the monitor is 1.8", the max distance is 2.438".  Can be used in wider cabinets by simply adding wood panels to the cabinet walls, or 2x4 supports in the area the monitor is to be mounted.  You can find dimensions for many common monitor models on the spec sheets at http://wellsgardner.com/service/
I'm selling these for a lower price than 4 years ago,  $50, which includes 3-day shipping anywhere in the US.  Includes instructions and all mounting hardware: 4 locknuts for the adjustment plates, 4 chassis bolts with nuts for attaching the monitor, 16 wood screws (3/4") with extra deep threads which cut into particle board and plywood without splitting.  The last batch I had sold out quick, and when these are gone, that's all folks.  I'm not making any more of these, the margins are just too low on small runs like this...
If you're interested, PM me and I'll send you the payment details.
-Rob ;D
Instructions can be found HERE
« Last Edit: June 16, 2009, 04:14:38 pm by 1UP »
My other job...
1UP
  • Token Junkie
    • 1UPArcade
Re: PRICE DROP! Adjustable Monitor Brackets - 8 available!
« Reply #1 on: May 06, 2009, 03:19:20 pm »
Price dropped to $50.
My other job...
1UP
  • Token Junkie
    • 1UPArcade
Re: PRICE DROP! Adjustable Monitor Brackets - only 7 left!
« Reply #2 on: May 07, 2009, 03:40:56 am »
Here's some feedback from previous customers:
"I just got my mounting brackets.  They look great and are very solid."  -Shmokes
"I installed mine today and they work great.  Easy installation for my Betson 27" monitor.  Thanks 1Up for a good product that was easy to work with!"  -Namedos
"I just wanted to say thanks to 1UP for providing a great solution and product for mounting my monitor. I received mine yesterday and it looks like it will work perfectly."  -Depressd
My other job...
1UP
  • Token Junkie
    • 1UPArcade
« Reply #3 on: May 08, 2009, 08:45:41 pm »
I'll be putting up some info on monitor sizes supported and mounting dimensions either tonight or this weekend for those who are not sure if this will work with their projects.
My other job...
XeviouS
  • Last login:March 11, 2016, 08:38:20 am
    • Noah's Arkade
« Reply #4 on: May 09, 2009, 03:22:15 am »
notaburger
  • Last login:April 16, 2021, 03:38:49 pm
« Reply #5 on: May 09, 2009, 06:11:24 pm »
what's the longest distance between bolt holes possible?
i'm needing to find a way to mount my 31" monitor
1UP
  • Token Junkie
    • 1UPArcade
« Reply #6 on: May 09, 2009, 06:51:30 pm »
Is there a chance the bracket could bend?
The brackets should not bend under the weight of a 27" arcade monitor or similar.  They are made of heavy gauge steel (3/32") and when installed are completely rigid.
To put it another way, here's a quote from RandyT, who helped me manufacture the initial run of brackets:
The only force you'd need to be concerned with is "shear", and with that many screws, assuming the sides of the cabinet are immobile, the force required to break it loose would be tremendous.
RandyT
« Last Edit: May 09, 2009, 07:13:52 pm by 1UP »
My other job...
1UP
  • Token Junkie
    • 1UPArcade
« Reply #7 on: May 09, 2009, 07:13:23 pm »
There is no limit to the horizontal distance between holes (between the 2 sets of brackets), but the vertical limit when the brackets are adjusted to their maximum length is a hair over 20 5/8" (20.644") which is typical for a 27" monitor with universal mount.  For a 31" monitor, you should be able to use the brackets without the adjustment plate, but I would recommend that you use carriage or socket cap bolts that go all the way through the cabinet walls from the outside to handle the extra weight.  I can provide you with some nice black oxide button cap bolts if you're interested.
« Last Edit: May 09, 2009, 07:37:58 pm by 1UP »
My other job...
1UP
  • Token Junkie
    • 1UPArcade
« Reply #8 on: May 09, 2009, 10:30:48 pm »
Updated the top post with some additional information on monitor sizes that can be supported.
My other job...
1UP
  • Token Junkie
    • 1UPArcade
This post is getting a little messy, so I'm working on a graphic that makes a lot more sense of the mounting measurements.  Will be up soon.
My other job...
Flake
  • Last login:December 04, 2023, 03:02:46 pm
  • I am Evil Homer....I am Evil Homer....
« Reply #10 on: May 11, 2009, 11:38:39 am »
Not on your life my Hindu friend!
Sorry.....couldnt resist......
My apologies...
XeviouS
    • Noah's Arkade
« Reply #11 on: May 12, 2009, 04:56:34 am »
My apologies...
1UP
  • Token Junkie
    • 1UPArcade
Bump -- a few more of these left.
My other job...
1UP
  • Token Junkie
    • 1UPArcade
Updated the top post with a diagram showing the important mounting dimensions.
My other job...
fa001
  • Last login:November 14, 2023, 11:17:08 am
If I had had this much info before I bought a set I may not have bought them. It turns out that the cab I have is 26.5 inches wide inside and I have a 27 inch monitor.  The brackets do not go for that width. However the cab does have bolts through the sides so I am bolting a 1 x 6 between the bracket and cabinet side on each side. That way I have the correct width for the monitor. The brackets are good heavy duty quality and I think that this will work.
1UP
  • Token Junkie
    • 1UPArcade
That's the recommended way to make it fit.  If you don't want to use bolts, you can just glue and screw some extra wood panels onto the inside walls of the monitor area.  Unfortunately, these aren't just going to drop into any cabinet size with any monitor size, some modifications may be necessary.  Some concessions had to be made to allow some flexibility while not compromising the strength of the design.  If I made the front mounting studs too long, they would not be able to support as much weight.
However, even with the addition of wood to the mounting area, this solution is usually easier and more stable than rigging something from scratch.
I'm sorry it took so long to get the dimensions up, but I hope the brackets end up working for you.
-Rob
« Last Edit: May 18, 2009, 02:53:26 pm by 1UP »
My other job...
1UP
  • Token Junkie
    • 1UPArcade
Just a couple more left!
My other job...
1UP
  • Token Junkie
    • 1UPArcade
Looks like I might have forgotten the instructions when I shipped a couple orders.  Sorry guys, you can get the instructions HERE!
My other job...
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
Thanks!  Just picked up one of these.  Should work good with my 27" betson multisync.
1UP
  • Token Junkie
    • 1UPArcade
Bump--still need to sell the last couple of these to make some room!
« Last Edit: May 27, 2009, 02:17:09 am by 1UP »
My other job...
1UP
  • Token Junkie
    • 1UPArcade
Anyone who has received these, please leave feedback thru the trader system under my profile if you could.  Thanks!
My other job...
1UP
  • Token Junkie
    • 1UPArcade
Re: Adjustable Monitor Brackets for 19"-27" CRT/LCD - only 2 left!
« Reply #21 on: June 07, 2009, 05:07:58 am »
Yup, still got 2 of these.
My other job...
Silverwind
I entered feedback but I went to add a quote mark to the 27" and I hit enter instead.  The feedback is short for that reason.  Is there anyway to edit my comment?
1UP
  • Token Junkie
    • 1UPArcade
Thanks for the rating.  I don't know if/how you can edit it but I wouldn't worry about it.  :)
My other job...
1UP
  • Token Junkie
    • 1UPArcade
Re: Adjustable Monitor Brackets for 19"-27" CRT/LCD - only 1 left!
« Reply #24 on: June 16, 2009, 04:14:26 pm »
Just one set left.  Any takers?
My other job...
1UP
  • Token Junkie
    • 1UPArcade
« Reply #25 on: June 25, 2009, 11:37:41 pm »
Bump.  One set of brackets remains...
My other job...
