Author Topic: Removed DVD-rom drive PC won't boot  (Read 1052 times)
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
« on: April 20, 2009, 03:43:23 pm »
I am buildign a JUKE and don't want a DVD-rom drive installed anymore.  I used it to load the os but when i discconect it from the system it won't boot.  How to I remove this DVD drive and allow the PC to boot up?
Ginsu Victim
  • Comanche, OK -- USA
Re: Removed DVD-rom drive PC won't boot
« Reply #1 on: April 20, 2009, 03:45:14 pm »
Did you check the jumper on the hard drive? Was it a master - slave setup?
JonProphet
  • Last login:December 03, 2009, 04:35:47 pm
« Reply #2 on: April 20, 2009, 03:49:03 pm »
Check your BIOS for halt on errors. If it had set that you had a drive and now its gone. It will halt. Also, did you remove the floppy to? Check that as well.
-JD-
Chunce DeLeone
« Reply #3 on: April 20, 2009, 04:13:54 pm »
The hard drive is actually a CF to SATA adapter so I didn't see a jumper on it, also the bios doesn't have no halt on errors.  I am goign to try and update the bios, maybee a newer one has that option, intel atom 230
Ginsu Victim
« Reply #4 on: April 20, 2009, 05:01:05 pm »
Some mobos look for certain SATA drives to be connected and if they aren't, it will halt. Check to see if that's the case.
BobA
  • What Me Worry?
« Reply #5 on: April 21, 2009, 07:31:47 am »
Check your BIOS and see if it lets you play around with boot order or priority and make your CF/ATA your first drive if you can.
NIVO
  • Last login:August 08, 2022, 12:32:13 pm
« Reply #6 on: April 21, 2009, 08:25:40 am »
yep boba has it, its the boot order that is the problem most likely. It was set for the dvd to boot first. Reconnect the dvd drive start pc go into bios, lookup boot priority and switch 1st boot device to your hard drive. Exit and save your settings, and power down. You can safely remove the dvd again, and reboot. It should boot to windows or whatever OS your using. If it doesn not, then there are bigger issues at hand.
Chunce DeLeone
« Reply #7 on: April 21, 2009, 09:08:13 am »
Thanks for the info guys!, I did a combo of things and it is working, I changed the boot priority and I turned of the IDE interface throug hte bios,  I wish I had read these posts before I did that cause I would have tried just changing the boot order
