Main > Main Forum
HOTD (PC) and Topgun- 2nd player doesn't work? *Resolved*
Pages: << < (9/9)
swamprat96:
Ah Canana - we are not worthy :notworthy: :notworthy: :notworthy:
It was Option 2 I had wrong. Should have seen it but fixed now- thank you!
HOTD 2 working fine. I am going back to PC for HOTD
David- try setting the topgun driver not to release the cursor to the mouse offscreen. Sems to work a whole lot better. No need to use smogs or acorns drivers- the new genuine beta2 drivers work fine
zaktallica:
Will this work for guncons? You guys have 2 guns working now?
swamprat96:
Yes this will work fine. Your guns will be seen as seperate mice by the troubleshooter
swamprat96:
Just to finalise- I have all troubleshooter PC games working perfectly with 2 players now. Admins- Could this thread be a sticky? Cananas's guide is excellent as it deals specifically with topguns - not covered on the troubleshooters site.
What everyone including me seems to miss is that you must make sure each device(gun) is assigned for each player- and that player1 and 2 are different.
A final tip- with Virtua Cop 2. It will not run in XP with light guns until you change the compatibility to Windows 98. It then runs fine. Also use closemul to run this software from an FE as you need the escape key to work
Cananas:
--- Quote from: swamprat96 on May 05, 2009, 07:29:16 pm --- Also use closemul to run this software from an FE as you need the escape key to work
Or you could compile something like these ahk (autohotkey) scripts for a more mame friendly game (they are old, made with different versions of Autohotkey, but they works...):
HOD
--- Code: ---Run,C:\Archivos de programa\D-Tools\daemon.exe -noicon -mount 0`, "C:\JuegosPC\The House of the Dead\MusicCD\thod_music.cue" ; load the cd music
sleep, 1000
Runwait,thotd.exe -d3d ; run the game
Run,C:\Archivos de programa\D-Tools\daemon.exe -noicon -unmount 0 ; unload the cd music
ExitApp ; End the script
; Key Mapping ===============
2::Tab
6::Tab ; '2'o '6' Start player 2
g::d ; 'g' right
r::w ; 'r' up
f::x ; 'f' down
d::a
a::Tab ; 'a' ok and 'fire'
s::LCtrl ; 's' back in menus and reload
1::Space
5::Space ; '1' o '5' Start player 1
LCtrl::Space ; 'LCtrl' OK and 'fire'
LAlt::NumpadAdd ; 'LAlt' back in menus and reload
*Escape::
PostMessage, 0x112, 0xF060,,, The House Of The Dead ; Send the message ALT+F4
return
--- End code ---
HOD2
--- Code: ---Run,hod2.exe
WinWait,House of the Dead2
Send {ENTER}
ExitApp
2::Tab
r::w ; 'r' up
f::s ; 'f' down
g::d ; 'g' right
d::a ; 'd' left
a::LShift ; 'a' ok in menus and 'fire'
1::Enter
5::Enter ; '1' o '5' Start player 1
LAlt::RCtrl ; 'LAlt' back in menus and reload
LCtrl::RShift ; 'LCtrl' OK and 'fire'
--- End code ---
HOD3
--- Code: ---; to avoid the annoying hod3 launcher
RegWrite, REG_DWORD, HKEY_LOCAL_MACHINE, SOFTWARE\SEGA\hod3\Settings, Played, 1
RunWait,hod3pc.exe
;Sleep, 4000
;WinWaitClose, THE HOUSE OF THE DEAD 3
ExitApp
1::Enter
2::t
LAlt::z
LCtrl::x
r::i ; Remap the keys according to MAME
f::k
d::j
g::l
a::n
s::b
q::y
Escape::
PostMessage, 0x112, 0xF060,,, THE HOUSE OF THE DEAD 3 ; Send the message ALT+F4
Send {i down}
Sleep, 10
Send {i up}
Send {n down}
Sleep, 10
Send {n up}
ExitApp ; End the Script
return
--- End code ---
VirtuaCop / Virtua Squad
--- Code: ---; Virtua Squad (To work on Home Arcade Cabs)
; Load the cd music
Run,C:\Archivos de programa\D-Tools\daemon.exe -noicon -mount 0`, "C:\JuegosPC\Virtua Squad\MusicCD\VCop_music.cue"
sleep, 1000
Runwait,vcop.exe ; run the game
ExitApp ; end the script
; key remapped ===============
p::F3
*Escape::
PostMessage, 0x112, 0xF060,,, VIRTUA SQUAD ; Send the message ALT+F4
return
--- End code ---
VirtuaCop2
--- Code: ---; Virtua Cop 2 (To work on Home Arcade Cabs)
Run,C:\Archivos de programa\D-Tools\daemon.exe -noicon -mount 0`, "C:\JuegosPC\VCop2\VCop2_music.cue"
sleep, 1000
Runwait,ppj2dd.exe ; run the game
ExitApp ; end this script
p::F3
*Escape::
PostMessage, 0x112, 0xF060,,, VirtuaCop 2 ; Send the message ALT+F4
return
--- End code ---
Pages: << < (9/9)
Go to full version
