Main > Everything Else
3d pinewood derby car made from Sketchup Pro model download
Ummon:
--- Quote from: shmokes on April 21, 2009, 02:16:09 am ---best trick to build a fast car is to bend one of the rear axles (the axles were just nails last I did one of these). This allows you to grab the tip with a pair of needle-nose pliers and twist it until you can get it so the car rolls without the wheel touching the ground. Three wheels is where it's at. And since rolling down the track itself bangs the hell out of it, you can test it between races and make adjustments if necessary.
I think the cars generally were off balance due to how the wheels are mounted.
--- Quote ---BTW, one year my older brother carved a replica of an Oldsmobile Aerotech Quad 4 for my pinewood derby. It was entirely by hand, mostly using an xacto-knife. Super cool. I wish I had pictures of that.
Thing is, there are cars that are actually luxurious, let alone functional, and probably a bit cheaper, that are faster. There's an Aston Martin I think I really like for only a few hundred thou and does almost three hundred. Great sedan.
shmokes:
--- Quote from: Ummon on April 22, 2009, 02:58:17 pm ---
Ummm . . . . errrrr . . . . umm . . . You do realize that we're talking about pinewood derby cars. They're not exactly known for being particularly luxurious. In fact, being that they are a solid block of wood I would say they are decidedly not luxurious.
Dartful Dodger:
--- Quote from: shmokes on April 22, 2009, 06:40:50 pm ---
Ummon's link is to a high end race carish thingy, by Oldsmobile.
I think they're trying to highjack this thread into who knows about the most obscure race car.
...I owned a Dodge Dart road race car with a slant 6 motor.
ChadTower:
...I had a Ford EXP with a custom convertible frame... that sucker could go zero to sixty in under 5 minutes.
Ummon:
--- Quote from: Dartful Dodger on April 22, 2009, 07:50:18 pm ---
I had a dart, too. My first car. Nothing special about it, though. Anyways, I guess I should've explained that I was referring to the Olds linked.
Navigation
[0] Message Index
[*] Previous page
Go to full version
