Main > Everything Else
extending electrical to the shed
ChadTower:
--- Quote from: Hoopz on May 05, 2009, 09:47:06 pm ---Do you have to cover the studs since the wiring is there for it to be brought up to code?
I asked about that and the electrician said no because it's not a dwelling. I'm tempted to cover just those spots, though.
Hoopz:
I wondered if it would matter since it wasn't a house. I'd cover it with peg board. Provides some protection and offers utility at the same time.
ChadTower:
Not too bad an idea. Maybe I can cover it with pictures of Peg Bundy. Best of both worlds.
Level42:
--- Quote from: ChadTower on May 04, 2009, 10:25:06 am ---l and switches for interior/exterior lights, GFCI outlet, and 240v box waiting for a device to need it.
I could send you a hair-dryer or something ;)
Overhere we'd run those wires in (flexible) PVC pipes normally. Also, those cables look like stranded right ? Has to be solid core here. However, I've heard they are leaving the rules a bit more free now so it's ok you leave out the pipe.
Since I wanted every single power outlet to power only 1 device, I opted for stranded wire too, and no pipes, would have been very costly. Don't tell anyone ;)
ChadTower:
The yellow wires are solid core... I believe the 240 line to that box is stranded, though. The lines inside don't need to be in a pipe but everything outdoors does.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
