Author Topic: how to mount my monitor  (Read 2093 times)
abzman2000
  • Last login:August 26, 2020, 06:25:12 pm
  • I LIKE my hat!
« on: March 30, 2009, 08:38:51 pm »
I'm looking for some feedback on my  (tentative) choice of monitor mounts.  images follow
my monitor is a WG 25" k7191
main project thread http://forum.arcadecontrols.com/index.php?topic=80852.0
« Last Edit: April 16, 2009, 03:40:36 pm by abzman2000 »
BobA
  • What Me Worry?
Re: how to mount my monitor
« Reply #1 on: April 01, 2009, 02:43:03 pm »
Not sure the overall support you are going to have but some of those strips of wood look a little thin for the weight and torque of a 25 inch monitor.   This is just a gut feeling from the pictures viewed.
abzman2000
  • I LIKE my hat!
« Reply #2 on: April 06, 2009, 01:59:49 pm »
that's what I was thinking, what is the conventional way to mount these sorts of monitors?
  • Last login:Today at 07:54:28 pm
« Reply #3 on: April 06, 2009, 02:17:29 pm »
Run a 2x4 or strip of plywood from underneath the v-shaped pieces you made to the base of the cabinet.  They will act like columns and distribute the load.  I think that will work.
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #4 on: April 06, 2009, 02:44:58 pm »
That looks kinda weak. I built a shelf... 1/2" ply with the bottom boxed using wood the size of your mounts. I built that to hold the weight and the top mount is just a small piece for position similar to what you're using.
The whole chassis rests on the shelf.
I was in a hurry to get it done the other day, so I didn't take pics as I was going, sorry.
Ed_McCarron
« Reply #5 on: April 06, 2009, 06:33:21 pm »
Yup.  That green tape will never hold.
Shelf.  Gotta be the easiest way to go, as long as the monitor will work with it.
abzman2000
  • I LIKE my hat!
« Reply #6 on: April 16, 2009, 03:39:03 pm »
shelf is in the works for the weekend, then prime and paint the rest of it.  It will probably be made out of 3/4" plywood, is that good enough?
BobA
  • What Me Worry?
« Reply #7 on: April 17, 2009, 08:45:08 am »
A 3/4 inch plywood shelf should be fine as long as it has good support along the sides.
hammyysu
  • Last login:May 19, 2014, 11:56:40 pm
« Reply #8 on: April 18, 2009, 01:55:01 am »
on my cabinet i use 3/4" plywood and for the braces i used anel iron to hold the shelf then screwed the wood to the metal. it works great. or find yourself an old cabinet and look how they did it.
