Author Topic: Mounting UltraStik 360  (Read 4661 times)
mikeveli20
  • Last login:May 01, 2009, 05:11:14 pm
« on: March 29, 2009, 04:54:53 pm »
Sorry for a noob question, but how does the UltraStik 360 come apart so it can be mounted to a control panel?
ids
  • Last login:April 16, 2023, 05:43:28 pm
  • Fighter Captured
Re: Mounting UltraStik 360
« Reply #1 on: March 29, 2009, 05:30:46 pm »
You don't really take it apart.  What you do depends on whether top mounting or bottom mounting.
For a bottom mount, you just need a hole ~1"?? for the shaft to get through and have enough room to move.  Remove the knob to get it through.
For top mount...not really anything to worry about, that I can think of.
Are you mounting to wood?  5/8" or 3/4"?  Or metal?  I'm guessing you don't have the sticks yet.
mikeveli20
« Reply #2 on: March 29, 2009, 06:29:09 pm »
It's 3/4" wood. I do have the sticks, but didn't realize you could just unscrew the ball top lol. I thought it would be the same as the mag-stik where you pull the whole stick out or something. Thanks for your help.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: March 29, 2009, 06:31:07 pm »
I certainly hope you ordered the longer shafts if you're bottom-mounting in 3/4" wood.
ids
  • Fighter Captured
« Reply #4 on: March 29, 2009, 07:01:45 pm »
I've bottom mounted in 3/4" with standard length shafts, and don't see any issues.
Perhaps it's a matter of taste, or what we're used to?  I can't debate authenticity, since I haven;t seen a Galaga machine in ...too many years to count.
TheShanMan
  • Last login:October 16, 2023, 03:35:12 pm
    • My Arcade (updated 1/30/13)
« Reply #5 on: March 29, 2009, 07:05:23 pm »
The longer shafts aren't that much longer anyway. It's whatever works well for you. Not all arcade games had long shafts anyway (e.g. defender).
Ginsu Victim
« Reply #6 on: March 29, 2009, 09:48:19 pm »
Actually, I'm using the standard shafts bottom mounted in wood and I like it, but some people don't care for it. On my friend's new control panel, they seemed REALLY short, so we made sure to order the long shafts. It made a difference.
severdhed
  • RIP Dinosaur Hippo
« Reply #7 on: March 29, 2009, 10:57:54 pm »
i went with the longer shafts, bottom mounted in a 3/4" panel...with the longer shafts, they were the same height as the x-arcade sticks they were replacing.
i dont think i'd want them any shorter than that
  • Last login:Today at 07:54:28 pm
« Reply #8 on: March 30, 2009, 12:41:22 pm »
you can get an extra 3/8" if you route out underneath the panel.  That's what I did and it made a big difference (i also have the long handles).
Franco B
« Reply #9 on: March 30, 2009, 12:49:55 pm »
You could also [top mount] them too.
Todd H
  • Last login:February 17, 2024, 12:58:49 pm
  • It's Gameday!
« Reply #10 on: March 30, 2009, 01:30:02 pm »
I have my U360's bottom mounted in my 5/8" control panel using the longer handles and find the height perfect.
paulscade
  • Last login:December 26, 2022, 09:40:35 pm
    • My Arcade Project - Blastoff!
« Reply #11 on: March 30, 2009, 01:49:38 pm »
Be sure to consider the orientation when mounting the 360's... they are not square and there is a top/bottom.  When I mounted mine "wrong", I didn't think that it would be too much of an issue (because I could simply program which way is up).... but then I realized that you can't program the direction for the analog mode.
In the end, there was a simple fix that I had overlooked:
http://forum.arcadecontrols.com/index.php?topic=82241.msg896290#msg896290
... Why is it that you always find it in the last place that you look? ...
Kayden
  • Last login:February 17, 2023, 07:20:44 pm
  • Oh crap! Is it suppose to spark like that?
« Reply #12 on: March 30, 2009, 05:28:56 pm »
I top mounted my 360s.  It's only hard if you don't already have a router.
I had a template that I designed in viso and transfered the dimensions of the metal plate to my CP with carbon paper.  In the center of the joystick hole, I drilled a 1/2" hole and inserted my joystick upside down.  I traced the plastic housing and then cut it out with a jigsaw.  Then I routed out the rest to a depth of about 1/8".  The plate sits flush with the top.
Sorry if this doesn't make as much sense as I want it to, I'm kinda sleep deprived.
