Author Topic: X-Arcade Programming?  (Read 3066 times)
johnnyr
  • Last login:April 06, 2009, 10:44:46 am
« on: March 27, 2009, 03:40:14 pm »
Hey Guys,
I know you are sick of all my threads, but this will be the last one (at least for the next 24 hours ;))
I just got my x-arcade tankstick, but I'm at work so can't try it out. My question is how this is programmed. I was reading some of the instructions for it, and it goes into how to program it etc....can I not just go into mame set the controls like I would with a regular keyboard? Someone help me out and explain how this works...
garnerb350
    • Hyperspin
Re: X-Arcade Programming?
« Reply #1 on: March 27, 2009, 03:45:15 pm »
If you got the manual...it has in there what you have set....
There is 4 settings ( i think)...1 is the factory setting, which in the manual it is for MAME (PC) the rest is programable modes...
You can dload the configuration file for MAME on the X-arcade website (under the customer support section)...throw that in the respectable file and if you go to default options ( i think)...you have a pulldown and you select "x-arcade"
( i think)...means I'm like you ...I am at work...
Ive never had to use the programable modes...( but I will eventually when I set up my Mugen Games...)
You CAN do what you suggested...but you would be doing more work than necessary
« Last Edit: March 27, 2009, 03:50:57 pm by garnerb350 »
johnnyr
« Reply #2 on: March 27, 2009, 05:25:23 pm »
Its this config file I don't get. I'm using the command line version of mame...so there isn't any options screens or pull downs except when I am IN a game. Is that what it means?
severdhed
  • RIP Dinosaur Hippo
« Reply #3 on: March 27, 2009, 05:32:36 pm »
copy the xarcade.cfg file into the mame\ctrlr folder..then in your mam.ini file, find the following section and make sure ctrlr is set to xarcade..
# CORE INPUT OPTIONS
ctrlr                 xarcade
mouse                   1
joystick                1
lightgun                1
multikeyboard             0
multimouse                0
steadykey               0
offscreen_reload        0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
johnnyr
« Reply #4 on: March 27, 2009, 05:38:18 pm »
ctrlr                 xarcade
mouse                   1
joystick                1
lightgun                1
multikeyboard             0
multimouse                0
steadykey               0
offscreen_reload        0
joystick_map              auto
Ok, I will need to make a Mame.ini...its mame -cc, right?.....also, since this is a tankstick and has a trackball, do I need to change the "mouse" value to something else? or put multikeyboard to 1? (since I will have the x-arcade and regular keyboard hooked up) Better yet, where can I get information regarding the settings in mame.ini?
severdhed
« Reply #5 on: March 27, 2009, 10:16:07 pm »
mouse set to 1 means that the mouse is enabled, which is what you want for your trackball.  you shouldn't need multikeyboard enabled.  as for where to find info on mame.ini..i dont know.
