Author Topic: Using U360's with Battlezone type games  (Read 1642 times)
cmoses
« on: March 26, 2009, 04:54:58 pm »
Has anyone been able to use a U360 with a game like Battlezone that had two joysticks for tank controls?  Is there a mapping for it?  If not could one be made so that it would work with that type of joystick?
TheShanMan
  • Last login:October 16, 2023, 03:35:12 pm
    • My Arcade (updated 1/30/13)
Re: Using U360's with Battlezone type games
« Reply #1 on: March 26, 2009, 06:31:11 pm »
Sure you could create a good mapping for it, but the real problem is the fire button. BZ kinda needs a trigger stick, although I suppose as a hack you could use a pedal to act like the fire button. :dunno
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: March 27, 2009, 01:34:48 am »
I think the OP is thinking configing one joystick to work with the two 2-way games.
Yup, can be done, and we've talked able it.  Let me see if I can find it... Here is the latest post on it, IIRC.
Robin
Knowledge is Power
TheShanMan
« Reply #3 on: March 27, 2009, 12:25:03 pm »
Cool! It hadn't even occurred to me to try to combine the 2 joysticks into 1. I might want to try that sometime. Probably makes it hard to play a real BZ machine once you're used to 1 joystick (there's one at the Ground Kontrol arcade that's not far from me) but I don't play it there all that often anyway.
cmoses
« Reply #4 on: March 27, 2009, 01:49:55 pm »
Yes I am trying to get one joystick to replicate the combinations of the two tank sticks.  I looked at that post and will give them a try.  With the two tank sticks there are only 9 combinations so you should be able to get that with a 8 way joystick.  Position 9 being not moved at all.
Ummon
  • Trade Count: (+13)
« Reply #5 on: March 27, 2009, 08:59:48 pm »
In the MaLa Umapper there's a 2-way vertical map, so yes it has been done.
Yo. Chocolate.
Stephen Hawking
TheShanMan
« Reply #6 on: March 27, 2009, 09:55:02 pm »
Ummon, I don't think you really read the posts in this thread. ???
TheShanMan
« Reply #7 on: March 28, 2009, 12:10:31 am »
Yes, this works great with the u360! Thanks u_rebelscum! :applaud: I don't know how you do "not's" in mame's config menu, so I did it by hand. Here's my bzone.cfg:
Code: [Select]
<?xml version="1.0"?>
<!-- This file is autogenerated; comments and unknown tags will be stripped -->
<mameconfig version="10">
    <system name="bzone">
        <video>
            <target index="0" view="Color Overlay" />
        </video>
        <counters>
            <coins index="0" number="33" />
        </counters>
        <input>
            <port tag="DSW1" type="DIPSWITCH" mask="3" defvalue="3" value="2" />
            <port tag="IN3" type="P1_JOYSTICKRIGHT_DOWN" mask="1" defvalue="0">
                <newseq type="standard">
                    JOYCODE_1_YAXIS_DOWN_SWITCH NOT JOYCODE_1_XAXIS_RIGHT_SWITCH OR JOYCODE_1_XAXIS_RIGHT_SWITCH NOT JOYCODE_1_YAXIS_UP_SWITCH NOT JOYCODE_1_YAXIS_DOWN_SWITCH
                </newseq>
            </port>
            <port tag="IN3" type="P1_JOYSTICKRIGHT_UP" mask="2" defvalue="0">
                    JOYCODE_1_YAXIS_UP_SWITCH NOT JOYCODE_1_XAXIS_RIGHT_SWITCH OR JOYCODE_1_XAXIS_LEFT_SWITCH NOT JOYCODE_1_YAXIS_DOWN_SWITCH
                </newseq>
            </port>
            <port tag="IN3" type="P1_JOYSTICKLEFT_DOWN" mask="4" defvalue="0">
                    JOYCODE_1_YAXIS_DOWN_SWITCH NOT JOYCODE_1_XAXIS_LEFT_SWITCH OR JOYCODE_1_XAXIS_LEFT_SWITCH NOT JOYCODE_1_YAXIS_UP_SWITCH NOT JOYCODE_1_YAXIS_DOWN_SWITCH
                </newseq>
            </port>
            <port tag="IN3" type="P1_JOYSTICKLEFT_UP" mask="8" defvalue="0">
                    JOYCODE_1_YAXIS_UP_SWITCH NOT JOYCODE_1_XAXIS_LEFT_SWITCH OR JOYCODE_1_XAXIS_RIGHT_SWITCH NOT JOYCODE_1_YAXIS_DOWN_SWITCH
                </newseq>
            </port>
        </input>
    </system>
</mameconfig>
Ummon
« Reply #8 on: March 29, 2009, 06:15:06 pm »
By his wording I didn't get that he wanted to use only one stick, and then I sorta glossed over his second post. In any case, I can't find it, so maybe it was a special build, but I swear I recall playing some fairly earlier version of mame that had this feature.
Yo. Chocolate.
Stephen Hawking
TheShanMan
« Reply #9 on: March 29, 2009, 07:03:27 pm »
Well, it doesn't need to be a feature of mame given that you can configure it to work as u_rebelscum indicated. And in fact it probably shouldn't be a feature of mame since that would be an inaccurate representation of the original hardware.
Ummon
« Reply #10 on: March 31, 2009, 06:19:29 pm »
I think it was the old GLBattlezone, actually.
Yo. Chocolate.
Stephen Hawking
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #11 on: April 02, 2009, 04:11:08 pm »
Not's are done by "double clicking" a direction.  Ands are done by pressing the other button/direction within less than a sec of the prior press.  Ors and done by waiting (for just over a second) for the prior map to register, then press enter and the next button/direction.
For example, to do:
Go to the input (joy right down in this case), press enter, then press down right right, wait until mame takes it, press enter, then press right up up down down.
If you're good at moves like this, it can be faster this way.  FWIW, I mess up a little too often, so have found editing by hand is just as for me (especially for remapping mice or trackball directions).
I was going to ref the mamedev wiki FAQs, but it's not very clear.  I'll edit it...  edit: okay, I think this is a little better.
« Last Edit: April 02, 2009, 04:19:26 pm by u_rebelscum »
Robin
Knowledge is Power
Ummon
« Reply #12 on: April 02, 2009, 10:56:58 pm »
'Not' in-game menu is double the direction you don't want. Enter>two quick pushes.
Yo. Chocolate.
Stephen Hawking
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #13 on: April 03, 2009, 12:11:29 pm »
Yeah, but you have to have something else mapped first, as mame doesn't allow a map of just a not: "not joy1 b1" is not valid, but "joy1 up not joy1 b1" is valid.  So you have to push the non-not key/button(s) before you do a the double push.  And mame has to have at least one non-not mapped before the double pushes work.  Examples: "enter,  A, A" doesn't register; "enter, A, A, W" registers as "A W" (both A and W need to pressed at the same time); "enter, A, A, W, W" doesn't work; and "enter, A, A, W, W, E" registers as "A NOT W E", which is the same as "A E NOT W" (both A & E keys have to be pushed, but the W key).
(If you understood all that, I'm sorry; I've been a bad influence. ;) )
Robin
Knowledge is Power
Ummon
« Reply #14 on: April 04, 2009, 04:50:30 pm »
Right. A lone 'not' give you 'none'. Well.
Yo. Chocolate.
Stephen Hawking
TheShanMan
« Reply #15 on: April 04, 2009, 05:05:59 pm »
Actually, a lone "not" would mean "anything but". ;)
Ummon
« Reply #16 on: April 06, 2009, 07:25:11 pm »
TSs-ss-ss-sss.
Yo. Chocolate.
Stephen Hawking
