Author Topic: Need suggestions on how to deal with T-molding Problem  (Read 1103 times)
Hoagie_one
  • Um....whats a cabinet
« on: March 26, 2009, 02:28:42 pm »
The cab I'm refurbing has a slot cut into it thats larger than standard T-molding fits into. The t-molding I bought does not fit snug at all and slides out with the slightest pressure, especially around bends.
Do they make a thicker slot t-molding or should I just use glue or discretely hidden nails \ staples?
ivwshane
  • Last login:December 24, 2022, 09:35:21 pm
    • My first mame cab! (WIP)
Re: Need suggestions on how to deal with T-molding Problem
« Reply #1 on: March 26, 2009, 02:35:34 pm »
I've read that a lot of people here have used hot glue in the slots to make it stay.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: March 26, 2009, 02:38:46 pm »
The other day I ran into a similar problem with a cab for my friend. What we did was took a piece of clear packing tape, cut it to about 2 inches long, looped it over itself so the sticky part was outside, laid it across the slot, then pushed the t-molding in. We did this every two feet and next to curves/corners. Worked great. The tape isn't visible, and the t-molding is holding well in place.
Hoagie_one
« Reply #3 on: March 26, 2009, 02:42:36 pm »
Gonna give this a shot.
thanks
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #4 on: March 26, 2009, 02:52:50 pm »
Hot glue FTW!
Working: Not Enough
Projects: Too Many
Progress: None
cmoses
« Reply #5 on: March 26, 2009, 04:49:45 pm »
I had a similar problem on my first cabinet.  Get some thin (width) masking tape and apply it to the T-Molding along the spline, folding it over so it is on both sides.  You may have to apply a couple of layers like this.  It basically builds up the thickness of the spline and allows it to grip when inserted into the groove.
evitagen
  • Last login:April 15, 2016, 10:43:40 am
« Reply #6 on: March 26, 2009, 08:39:26 pm »
I had this problem with my Control Panel... for some reason I cut the slots a size too big.  Not really sure why, since I did the rest of the cabinet the correct size.  Anyway... hot glue works great.  And it's so very easy.
Hoagie_one
« Reply #7 on: March 27, 2009, 01:31:16 am »
I went with the hot glue.  Worked awesome.
