Main > Main Forum
New Cab Builder! A few questions.....
chrisnack:
i have used various version of mame, currently running .129
johnnyr:
Ok, Thanks for the info. Now I just need to sort out the coin buttons. I've decided I'm going to wire them to my power supply to light them, and on the left one, wire it to the power sw on my motherboard.
My issue is how I will add credits. I'm going to be using the tankstick, and with the UAII the side buttons are unfortunately hidden (at least I think they are)
So...whats the best way to add credits with the tankstick? (with the UAII) Do you guys just disable the whole credit system in mame? Can you? Do you have any other suggestions?
chrisnack:
move your side buttons :)
taht's what i did, i moved them to the top of the panel
johnnyr:
--- Quote from: chrisnack on March 20, 2009, 11:36:42 pm ---move your side buttons :)
I can't move them, this is the arcade tankstick....If I did I would have to take it apart. Is that what you mean?
What about simply setting the coin up button to be the pressing of two buttons? For example hitting the player start and button 6 at the same time. I can do this in mame using the keyboard, but don't have my tankstick it try it out. Does this work? Or does the tankstick not recognize simultaneous button presses?
chrisnack:
I have a tankstick, take it apart and move the buttons, or deal with them being hidden, your pick... It's not hard to move them at all..
1-1/8 hole is what size you need to drill for the buttons...
