Author Topic: Sanwa JLW-UM-8 Questions  (Read 5905 times)
joshwaan
  • Last login:April 24, 2017, 07:51:23 pm
« on: March 20, 2009, 06:07:00 am »
Hi Guys
I purchased 2 of these sticks I heard Sanwa is good. I got the GT-Y Octagonal Restrictor Plate also.
But for the life of me cannot get the swtichs to work once'I've screwed it in. It's like the metal bar bit need's to go up so that the switchs will click and buttons will work.
Can anyone give me some advise?
Thanks very much
Josh
Ginsu Victim
  • Comanche, OK -- USA
Re: Sanwa JLW-UM-8 Questions
« Reply #1 on: March 20, 2009, 08:20:13 am »
According to LizardLick.com, the octagonal plate is for the JLF only. Could that be the problem?
joshwaan
« Reply #2 on: March 20, 2009, 08:24:20 am »
This is possible. it's like the shaft is too long and does not connect with the microswitchs.
When i pull up on the shaft and move the shaft it connects np with the micro's.
The guy I purchase it from said it work fine. fine ---my bottom--- :P
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: March 20, 2009, 03:44:55 pm »
Thats correct, the Sanwa octagonal is not for the UM-8.
Our octagonal for this stick was tooled-up and produced by us as Sanwa dont produce one.
Andy
Ginsu Victim
« Reply #4 on: March 20, 2009, 03:48:16 pm »
Well there you go. Thanks for clearing that up, Andy.
joshwaan
« Reply #5 on: March 20, 2009, 08:07:39 pm »
I'm pretty disappointed in these joysticks.
What's the best one for Street fighter 2 Alpha, I feel like I'm battling the controller with the current one.
Cheers
Josh
Bender
« Reply #6 on: March 20, 2009, 09:33:25 pm »
I just got mine hooked up and I like em'
I have the 8 way (Square) restrictor installed for SFIV and I think they work great, I did put a stiffer spring in though
r3ll1k
  • Last login:June 12, 2013, 05:46:59 pm
« Reply #7 on: March 20, 2009, 10:52:58 pm »
Cheers
Josh
I like using Happ competition joysticks. They feel better than the Ultimate joysticks and the ultimate is what is used in most amercian arcade fighting cabs.
