Main > Project Announcements
SF IV wirless arcade sticks for xbox 360/PC - Moved to BST
SG Jaycurl:
Thanks for showing the pics, and nice work. I've just started on my first stick, but I'm also stuck in the vortex of waiting for parts. I just switched my order to Happ from Sanwa parts, mainly because of the familiarity thing (and the fact that JLF sticks are pretty much sold out all over the place).
I saw that the sticks you made are just under 3", but could you share the rest of the dimensions? Having not done this before, I'm a little nervous about building a case that doesn't leave enough room for everything I need to cram in there. I plan to do the full 8-button layout similar to what you've done.
odysseyroc:
Great looking sticks! I have a couple of questions. What thickness is the top panel on those and how do recess those buttons on the sides?
cappadonna:
Sorry, been away for a bit. To SG, The deminsions I currently use are 12"W x 9"L x 3"H. I will admit, this leaves a tight space inside. However, If everything is positioned correctly everything fits fine. I do not suggest using terminal blocks with this size. I use QuckD's
on the microswitches to adjust for that.
To odysseyroc, the panel thickness is 3/8" thick (don't fret, very sturdy). To counter-sink the holes I use Forstner bits. Larger one first, then 1 1/8 for button hole.
Here are a couple more sticks. All of these are wireless.
I know, ditch the red stick :banghead:
Working on this one now. No longer placing start button on face of controller. Moved to back with other admins.
cappadonna:
My second Ken stick is almost finished. Have to connect the wireless pcb and add battery pack.
cappadonna:
Moved to buy/sell/trade.
Navigation
[0] Message Index
[*] Previous page
Go to full version
