Author Topic: Anti glare coating for glass?  (Read 1389 times)
ivwshane
  • Last login:December 24, 2022, 09:35:21 pm
    • My first mame cab! (WIP)
« on: March 12, 2009, 04:40:43 pm »
Is there a coating I can put on glass (after the fact) that will reduce glare? If so how expensive is it and what kind of draw backs does it have?
Any links would also be welcomed.
BobA
  • What Me Worry?
Re: Anti glare coating for glass?
« Reply #1 on: March 12, 2009, 05:45:52 pm »
Here is a link to a plastic sheet that can be applied to your flat glass (not for curved crts)
http://www.photodon.com/lcdprotect-sheet.htm
I have had experience with a spray that a service co applied to our curved crt monitors.   It was only marginally effective and wore off over a short period of time.  I would not recommend a spray on coating due to the low durability.
Major things to note are loss of some contrast and brightness.  In color critical applications it can mess up the true colors that maybe important for viewing documents and pictures before printing.
ivwshane
« Reply #2 on: March 12, 2009, 10:43:32 pm »
I don't know if that's what I'm looking for after reading this from their site:
I have a custom built arcade cabinet with a 2ft square sheet of safety glass in front of a regular CRT monitor. However I do have a bit of a glare problem coming off the glass sheet, and I am wondering if your product would adhere to the glass (versus the material LCD screens are made of)?
The film will adhere to regular glass just fine, however, these films are made to go directly onto LCD screens. When placed on glass and not in direct contact with the image you get a opaque pane of glass
BobA
  • What Me Worry?
« Reply #3 on: March 12, 2009, 11:50:56 pm »
The curve on the CRT messes it up.  I thought that when you said glass you were meaning a flat sheet, sorry if I misunderstood your intent.
ivwshane
« Reply #4 on: March 12, 2009, 11:58:27 pm »
No I meant a sheet of glass, not a crt.
The way I read their faq seem to indicate issues with anything except lcd.
Kevin Mullins
    • Me on Myspace
« Reply #5 on: March 13, 2009, 02:49:14 am »
I think what they are saying is that if there is a gap between the film and the actual image producing screen it may become opaque.
Kinda like a privacy shower door or something.
If the person in the shower gets real close to it people can see what's going on.
But if they step back from it then it becomes more opaque and unclear.
So they want the film applied directly to the image producing screen.
Which in your case wouldn't help the glare situation.
Wonder if there is like an automotive window "tint" of sorts that would work ?
Xiaou2
  • NOM NOM NOM
« Reply #6 on: March 13, 2009, 09:10:28 am »
Games like Galaga placed a dark translucent plastic sheet in front of their monitors.
It might even be polarized.
 They also used the cabinet sides with deeply sunken in monitors, to help shield out
anything else.
 You may want to try an Automotive tint film over glass.  Maybe you can find
some polarized film, and report the results.
