Main > Project Announcements
Defender MAME Project
Pages: << < (21/21)
martoon x:
--- Quote from: dextercf on October 14, 2011, 06:06:32 am ---Amazing build!
i appreciate it
martoon x:
--- Quote from: leapinlew on July 20, 2010, 09:05:25 pm ---
--- Quote from: martoon x on July 20, 2010, 02:24:16 pm ---
--- Quote from: leapinlew on July 20, 2010, 02:10:22 pm ---Good job.
Some artwork would push this cabinet over the top. Looks like you spent a bundle already, but any plans for art?
Thanks! Like I mentioned, it's a bit raw right now. I still need to add all of the graphics. Side art, control panel and bezel. I tried stenciling the side art, but that turned out to be an epic fail. Stencil came out great, but my adhesion skills are lacking. Can anyone recommend a reputable vinyl graphics guy?  In the top of this post I have some samples of overlays and stuff I was designed up
You did mention that. I just assumed that since it's playable...
i hear ya
Yvan256:
--- Quote from: martoon x on October 15, 2011, 02:22:39 pm ---My wish list
* replace marquees with LCD display
The problem is finding an ultra-wide display with the width your cabinet requires. A few people already know about those "mirror LCDs". A lot of them are 800xRGBx240, but only 10.2" with composite video inputs.
They would be perfect for a small desktop cabinet (especially if someone could hack it to accept a DVI signal) but not for a cabinet like Defender.
martoon x:
--- Quote from: Yvan256 on October 15, 2011, 06:01:11 pm ---
Can multiple displays be hooked up at once? It would most lilely be expensive (additional  video cards) and there would be at least three verticlal lines visible from the bezels...
Yvan256:
--- Quote from: martoon x on October 15, 2011, 08:12:28 pm ---Can multiple displays be hooked up at once? It would most lilely be expensive (additional  video cards) and there would be at least three verticlal lines visible from the bezels...
Since it's only a marquee, even a low-bandwidth video card on an old 8-bit ISA bus would probably suffice.
The best solution for the multiple-LCDs-for-the-marquee idea is probably going to be a video splitter, which would appear as an ultra-wide videocard to the computer and split the image itself to the multiple monitors. I think ATI (ahem, AMD) has (had?) such products.
Pages: << < (21/21)
Go to full version
