Main > Everything Else
Bittorrent question (uTorrent)
shmokes:
I am running Tomato on the router, FWIW.
ChadTower:
Oh good, so if it's a bug in the firmware only, then you should be okay. I still run the default and uTorrent causes it to drop for 45-60 seconds fairly often.
Red:
--- Quote from: ark_ader on March 02, 2009, 07:54:19 pm ---Update your tracker.
PG2 is really good, Utorrent keeps records of users, so maybe it is moot.
What tracker do you recommend?
AtomSmasher:
I had an odd torrent problem a while ago where it would download fast for a 5-10 seconds, then not download at all for 30-45 seconds, then repeat. The problem ended up being my torrent client was using an old version of java, even though I had the latest version installed. I went through the add/remove program list and uninstalled every version of java except the latest one and it fixed my problem.
Navigation
[0] Message Index
[*] Previous page
Go to full version
