Main > Main Forum
Name that mame
Malenko:
yeah thats the tricky part, Midway used the same basic cab for 2 and 4 player games (NBA Jam, NHL Open Ice, Killer Instinct, Mortal Kombat,etc) and even the same coin door, just with an extra set of mechs )hence the wider door. I think Konami did the same thing, used identical cabs for 2 and 4 player but instead of cutting out 2 holes for 2 sets of coin doors they just cut one in the middle.
all the pix I fond of Martial champion dedicated cabs look just like your cab, so its my best guess it was a martian champion. the only other US released konami game in the US in 1993 was Gaiapolis and it was a vertical game.
femartinez13:
yea its making more and more sense that it just might be a MC arcade and another thing I remember is that there was no hole or opening like to insert a big control panel like a 4 player or mortal kombat one, so it looked like they just had a flat piece of board as the control panel. This is like the best pic I can find, so I think it just might be that :applaud:
Kevin Mullins:
--- Quote ---naw I put that cheesy Martial Champion marquee on there.
So where did you get your marquee from then ?
--- Quote from: femartinez13 on February 18, 2009, 05:39:36 pm ---another thing I remember is that there was no hole or opening like to insert a big control panel like a 4 player or mortal kombat one, so it looked like they just had a flat piece of board as the control panel.
So did you cut it out then to make room for the X-Arcade unit?
The squared off area is what made me think it was originally a four player cabinet.
femartinez13:
I got it from mamemarquees.com, and yea I had to cut off a chunk to make room for the tankstick. I wish i still had my old pics that I took when I first got it, I will have to look around...but anyways when I first got it, it had the t molding going all the way from top to bottom, like there was no spacing or piece removed around the cp area, thats what through me off even more cause I couldnt figure what type of panel would fit there.
Kevin Mullins:
Ah .... now that makes a big difference.
Meaning it was NOT a four player machine originally.
