Main > Main Forum
Any X-Arcade users out there?
dreamakuma:
Have the two player duo, and I'm happy with it. I also have happs buttons/joys on another cab. I enjoy both. the only thing that i'd like more is if the had ball-tops on xgaming's site. as for compatablity, never had a problem, I don't have a .cfg for it, just do tab,works. but the wiring is very tight, and a pain to work with so my whole unit is mounted, for ease.
garnerb350:
FIXED IT!!!!!!!!!!!!!!!!! :laugh: :laugh: :laugh:
It was my mame folder....I found a zipped file hidden in a wrong folder and found the x-arcade cfg.
MAME works perfectly....Also last night I got MA configured with the Tankstick also....
One thing remains though...
The 2 back white buttons ( on the left and right sides)...Has anyone figured how to use them?
I had the X-arcade tester and also opened notepad and when I hit those 2 buttons....nothing came up...Does anyone know about this? ( or do I need to open the panel up and see if they are connected?)
DeLuSioNal29:
Glad to hear that you solved it! Welcome to MAME!
dkubarek:
I think the one white button on the back right is to switch to modes 2, 3, and 4. You have to move the position switch to the desired mode (after you programmed it) and hit that button to change modes. Not sure why you would have one on the left, tho. I don't have the cp, tho, just the parts.
chrisnack:
--- Quote from: garnerb350 on February 12, 2009, 08:36:02 am ---FIXED IT!!!!!!!!!!!!!!!!! :laugh: :laugh: :laugh:
The 2 buttons on the side closest to the "front" are analog/digital conversion buttons for when using it with an xbox or something, the farther back side buttons are the coin buttons.
Tankstick works great with the latest beta of Maximus.
