Arcade Collecting > Miscellaneous Arcade Talk |
How farfetched is this? [regarding BYO pinball machine] |
<< < (2/2) |
madk:
Wow 2 free machines...that would make me a happy man. |
Ledbetter:
You might want to rethink using a tv or a high dot pitch arcade monitor. With pinMame you want the best monitor resolution you can get and no scanlines. |
Lilwolf:
True on the high res! I'm doing 640x480 and 8x anti - alias. Not bad. But not as good as 1200x1024! |
Molloy:
I think the wonderful tactile feel of pinball is lost through emulation. If could be just as cheap to hunt down a 2nd hand Twilight Zone (restoring and maintaning them is a big enough project for the most ambitious of handymen). The modern classics are pretty common and fantastically designed. There's so much depth in some of the new ones you could never get tired of playing them. |
arcadepcnut:
--- Quote from: Ledbetter on June 25, 2003, 06:28:32 pm --- You might want to rethink using a tv or a high dot pitch arcade monitor. With pinMame you want the best monitor resolution you can get and no scanlines. --- End quote --- yeah your right. Scatch this idea cause even a 19" monitor is to small to do this. A 27" tv was pushing it. |
Navigation |
Message Index |
Previous page |
