Main > Everything Else
Household Electricity Consumption
<< < (2/7) > >>
Kevin Mullins:
We had actually contacted the Electric Company a few times regarding such things, but essentially all we get is "sorry, can't help ya .... here's your bill".
Because we were both used to companies that had programs that would help pinpoint major changes in usage, etc. (energy conservation and all that)
Our last bill showed a usage of 5840 Kilowatt Hours -  that's a $353.64 bill.  :P
And this keeps changing drastically each year it seems from month to month if you were to look back at the history. (and of course it's a rediculous amount of usage as is)
So we're wanting to take a good look at appliances and such to start with.
Well, while the teenagers were all out of the house and it was just the two of us and the baby we were able to shut the house down completely and start going through at least the major appliances to see what they draw. I only bothered with those because of the digital electric meter made those easy due to the fact that all the major stuff is on separate breakers anyways.
So while the rest of the house was OFF we would just turn on one 220 breaker, turn the appliance on and read the meter so to speak.
I'll do some of the 110v stuff on an individual basis once I get one of those gizmos like I can just plug stuff into.
But non-the-less we have already found some rather surprising things going on.
I tried to make sure and take readings once an appliance "stabilized", because the initial kick on always a bit more, but then they usual come to a stable point and remain there.
The furnace is definitely a friggin' power hog. Which surprised me only because of how much of a hog it really was and it's only a 110v blower motor, only the heating elements are 220v.
15.3kw (and did have one spike that was like 19.9)
Dryer
4.85kw
Water Well
1.90kw (1HP motor)
A/C - which also surprised me because it's old as dirt so it did better than I expected. (It's like 15 years old)
4.40kw
Hot Water Heater - this one was kinda a killer too
5.30kw
Stove Top
Large Burner - 2.42kw
Small burner - 1.23kw
All four burners - 7.20kw
Oven - Needs new electronic control, so we don't even use it right now. (sometimes works, most of the time doesn't)
???kw
Refrigerator - Now here is one that we are seriously investigating. We have had it set at the initial setting it tells you which is like 5. It's really not a super old fridge or anything and it's very quiet, just an ever so slight hum. The more we thought about it the more each of us thought "hmmm...... I don't think I've ever heard it change tones". Meaning "is this thing ever turning OFF ??" So I've turned it down a little more and we're going to monitor when and how often it cycles.... if ever. But the current draw itself seems low for a compressor, but the question is whether or not it's running all the time.
.220kw (220watts)
I still have that random approximately 6kw draw I need to isolate, which I saw again today when I first started checking things this morning, but the entire house was still on and that just wasn't going to work for accuracy. I looked at the meter one minute and it said like 1.7kw, turn back around and it showed 7.8kw or so for a bit and then went away and neither of us had a clue if anything "came on" and then shortly after... it just went away. I never saw it happen again after we started doing the one for one checks with everything else off.
So I'll have to scrutinize the 110v lines next for sure.
Or maybe I'm just paranoid now because of the bill last month. Making me see things.  :laugh2:
I'll try to upload a pic of the Electric Meter I've been referring to, but right now it won't let me.
 :dunno
Kevin Mullins:
The pic shows the electric Meter I've been referring to.
Where you see the .811 kw is what I have been watching.
It's a current load reading basically.
So I would start off with it at .000 kw and then turn something on and then just watch it.
Kevin Mullins:
Oh.... and "the bus" only pulls about 1.53kw when everything is running.
That's 10 machines, a candy crane, a kiddie ride helicopter and an air hockey table all at the same time.
Not too shabby there.  ;)
Blanka:
- ditch the dryer. If you have room to hang out the stuff, opt for that. It even saves on the clothing bill
- get an offer for a heat-pump. If you do all heating of water on electricity, a heat pump is very interesting as it has a efficiency of 400%. You normal stove is probably only 80% efficient.
or
- get an offer for some hot-water collectors on the roof. They are cheap and fill in at least all summer hot water loads and they lower the winter use as well.
- is there natural gas laying in the street?
shardian:
Use cold water formulated clothes detergent. It will save you a tank of hot water, and about 50 cents per load.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
