Main > Everything Else
Terastation died
shmokes:
--- Quote from: patrickl on February 05, 2009, 06:25:59 am ---Like ahofle I fail to see how a single broken disk can be a problem. You remove the damaged disk and insert a new one.
Forgive me, but that's like someone complaining about car with a historically unreliable starter and responding to them with, "I fail to see how your car isn't starting. You put the key in and turn it."
Of course that's how the RAID array is supposed to work. How things are supposed to work are oftentimes not the same as how things in fact work.
patrickl:
--- Quote from: shmokes on February 05, 2009, 01:51:31 pm ---
Lol, don't you realize how ridiculous that sounds? Would you keep on using a car that doesn't start reliably?
It's even worse since by using multiple disks in a unreliable RAID configuration you have actually increased the chances of losing your data and als that you will lose ALL your data. Simply putting a number of extra harddisks in a PC (in JBOD configuration) would be a better option already.
If Terastations are indeed this crappy then I can only agree with Donkey_Kong. Try to get rid of that thing.
I'd suggest getting a Popcorn Hour A110. It's a file server, it can play HD content right on your TV and it can download stuff from torrents or usenet right on the box. Since it only uses a single disk it's safer than your Terastation.
saint:
Did you really just suggest that RAID was *less* reliable than a single disk?
*boggle*
edit OK - I just re-read that, and I'm going to take it you meant that the Terastation RAID was unreliable, not RAID in general.
patrickl:
--- Quote from: saint on February 05, 2009, 02:37:17 pm ---Did you really just suggest that RAID was *less* reliable than a single disk?
*boggle*
Yes indeed I meant
--- Quote ---an unreliable RAID configuration
Apparently a single disk failure on the Terastation can cost him the whole array. A single disk would seem a lot safer in that situation.
shmokes:
edit: Patrick responded while I was writing this, so there are some redundancies. Sorry. I'd edit, but I gotta get to class. :)
Well . . . it's an exaggeration of my position, but he means that if my chances of rebuilding my array are virtually nonexistant, then a single hardware failure is tantamount to all four of my hard drives failing. Thus by raiding the drives together I have multiplied the danger. Had I mounted the drives individually and one drive died, I would only lose up to 25% of my data, but if RAID isn't going to do it's job and any one of the four drives fail, I lose 100% of my data.
Of course, that's not my position. Terastations have a bad track record, but that just means I'm nervous. Obviously they work a lot of the time. Otherwise Buffalo would get sued out of existence. Additionally, when I made my first post I did not know whether it was a controller failure or a drive failure. I actually suspected controller because the web interface did not work (though I could ping the address) and the physical power button on the drive wasn't functioning. Cutting the power and rebooting corrected both of those problems, though. At any rate, my exact words when it began to look like merely a drive failure were, "I'm temporarily heartened . . ." I.e., okay . . . if it's just a drive failure I may be alright after all. I'll replace the drive and cross my fingers.
I would love to have a more robust storage solution. I took a risk with the Terastation cos it had just hit the market (i.e., no track record), and it cost about 1/3 what it's nearest competitor was charging for a similar feature set. I'm now a student with no income. I can't just up and say, "Hmm . . . I'm not very satisfied with my 2 terabyte network attached storage solution, I'll think just buy another and then sell this on Ebay." The reality of my situation is something more along the lines of, "Okay . . . it's the beginning of the semester so I haven't burned through all of my student loan money yet. A new drive for this will cost me $60-70. I think I can swing that. I hope to god it works . . . cos there's no way I can sink any more money into it at the moment."
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
